Author Topic: Steadfast column protector  (Read 15816 times)
« on: November 19 2011, 09:46:45 AM »
Gordy, do you have a picture of yours installed?
Their website is lame.
Re: Steadfast column protector
« Reply #1 on: November 19 2011, 10:45:05 AM »
If he doesn't, I will try to remember to take a pic of one of my cars
Offline gordyzx9r
  • The Sultan of Swank
« Reply #2 on: November 20 2011, 09:40:42 AM »
I don't (which is odd), and I won't be able to for a couple of weeks until I get the car back.
« Reply #3 on: November 20 2011, 09:56:53 AM »
What's the one that sticks on? Glues on?
Offline gordyzx9r
« Reply #4 on: November 20 2011, 10:43:02 AM »
Glue?
The one I have uses rivets.  I think you can also buy one with a kryponite style lock (the orange ones that Kirban and a few other vendors used to sell).
The Steadfast column guard comes in black and I tried to have mine painted to match but it's a bit lighter grey than the column.
« Reply #5 on: November 20 2011, 10:37:52 PM »
It's held on by a "captured" roll pin set up. Make sure you go through and check all the parts in the column before installing it or it's a total bitch to get off.
« Reply #6 on: November 21 2011, 09:51:01 AM »
Got it.
If/when I do get one, I would rebuild the column, put in a new turn signal switch, stalk, lock cylinder/etc
« Reply #7 on: November 21 2011, 11:35:00 AM »
I installed this one in about 1995.  Probably have not cleaned it since according to these pics.  I did not paint it as I thought maybe it would discourage someone from trying to pop the column if they saw it.   As said above, it is a clam shell held together top and bottom with blind roll pins.  Takes a cut off wheel to get it off.  Covers the key cylinder as well.
« Reply #8 on: November 21 2011, 01:52:29 PM »
I would like it more if it had a flat piano hinge or something on the top. I will probably still get one - I've grown weary of replacing steering columns.
« Reply #9 on: November 21 2011, 02:01:38 PM »
Indeed, it would blend nicely when painted if not for that top bit.
Maybe the steel is springy enough to wrap without a hinge?
Thank you for the pictures Steve.
« Reply #10 on: November 21 2011, 02:14:26 PM »
From what I remember about them they're pinned top and bottom. No hinges on it.
« Reply #11 on: November 21 2011, 02:31:00 PM »
I doubt it would be flexible enough to slide over without doing any damage to the stock column
« Reply #12 on: November 21 2011, 05:08:14 PM »
It is not flexible at all.  The joints are not particularly noticeable unless viewed from the camera angles.  Ot better than those big bulky locks that people used to buy
Offline gordyzx9r
« Reply #13 on: November 21 2011, 06:44:04 PM »
I thought it would bug me, but it doesn't...I wound up putting grey velcro strips in lieu of the black stickers that you see on Steve's car (because I couldn't find matching grey stickers and I didn't want people to be able to see the pins and think they could just knock them out).  I've seen a a few pics where people used that area to mount a tachometer.
