Author Topic: I didn't buy anything for me or the cat, but the fckng Buick did ok this X-mas..  (Read 16739 times)
Offline 87natty
ah a 208/208 ..... good choice
Offline 87natty
I'm more worried about the cut on the lobes so #3 exhaust doesn't wipe.
Offline Recklessrob
I'm still contemplating going to a roller setup to avoid that.
Rob
Offline 87natty
Does the block need to be modded for the setup? What does it involve?
Offline gordyzx9r
  • The Sultan of Swank
What would a stage II long block minus the heads & intake bringt?  Never bored, a dozen passes, 3/8"(?)...something about being one of the indy motors, a Siemens?  Has the cam, crank, etc...but it needs heads & intake.
I have been offered one...but the price seems steep to me.
Offline Recklessrob
Quote from: "87natty @ Sun Jan 08, 2006 2:02 am"
No. Everything bolts in.
Gordy, as for the stage block. There are a few variations, so the price
also varies. Unless you're planning on 9's or faster, they're just not necessary.
Rob
Bringing one back from the dead!
