Nasty Wendy Isn't
Why dont you just turn up the boost and stop spending money.....?
Just think, Sylvan & Phil, my car might be as fast as you guys in a while?
Still? Did you mean your car, Phil's car, or mine?
Quote from: "Gary Wells @ Tue Dec 27, 2005 3:05 pm"Still? Did you mean your car, Phil's car, or mine?I mean mine.....and it sounds like Phil's is not doing so hot, either. Hopefully this here cam sensor will fix my shit.
Sylvan: What is the car doing when you try and start it?Does it start but only run at a very fast idle?
Quote from: "Gary Wells @ Tue Dec 27, 2005 4:50 pm"Sylvan: What is the car doing when you try and start it?Does it start but only run at a very fast idle?No, it just cranks and cranks but never fires....if you start it with ether, it fires right up and once it's going it runs like a top. Everything, and I mean EVERYTHING, other than the cam sensor has been swapped and nothing has solved the problem. Oh well, new cam sensor came in today.
