Author Topic: Whats wrong with my car.  (Read 63736 times)
Offline ledzeppac
« Reply #30 on: December 26 2005, 01:13:15 PM »
Thanks for the comments on the car....
I started it right up yesterday and no code....  I'll see today what it does....
Offline 87natty
« Reply #31 on: December 26 2005, 01:14:43 PM »
Check your harness grounds behind the heads, next to the firewall.
Offline Recklessrob
« Reply #32 on: December 27 2005, 01:15:07 AM »
Quote from: "87natty @ Mon Dec 26, 2005 5:34 am"
Bah! A properly tuned Q-Jet (feedback! No less!) will hand with a Holley and get better gas mileage. It's all in the hanger, needles and air valve. But that's also a lot of scrounging in boneyards. I love my Q-Jets. AFB's don't flow enough and Holley's flow too much, at least for me.
It all depends on what your demands are. The AFB works fine on a V6. I have
a Q-jet in the Grand Prix that works just fine too. Feedback as well.  I used
to have a Q-jet on the Mazda, but it was simply too much for the truck. When it comes to racing, holleys (and modofied holley designs ex Demon, BG etc...) are hard to beat because there is so much available for them. Even Nascar uses them.
Especailly important when you go big. I'll take a 750 cfm Holley over a 750 cfm
AFB or 795 cfm Q-jet anyday. IMHO
Rob
Offline ledzeppac
« Reply #33 on: December 27 2005, 12:47:22 PM »
Ta60 is on....  runs much better...  stronger....
But I dotn think I can drop the hammer into boost,  I still have to role into boost...   never ending with the car.
I think I'm going to get it washed and waxed today along with fixing the headliner
Offline Recklessrob
Re: Whats wrong with my car.
« Reply #34 on: December 27 2005, 01:05:59 PM »
its 'bout time you got that thing on. :psix;
Rob
Offline ledzeppac
« Reply #35 on: December 29 2005, 09:57:28 PM »
hmmm  ok does not knock with 100 octane but it is running extrememly rich...  o2's 845 boost was only at about 11 lbs and it was slow but at least it wasnt knocking...  I wil get more into details later.
Offline Recklessrob
« Reply #36 on: December 30 2005, 12:41:55 AM »
Quote from: "ledzeppac @ Thu Dec 29, 2005 9:57 pm"
hmmm
Rob
Offline ledzeppac
« Reply #37 on: December 30 2005, 02:06:10 AM »
I want to but it knocks like crazy with 91 and I'm scared to lean it out.  I seriouslyt get like 5 and up all the way to 10 degrees of knock at like 7,8,9 lbs of boost?????
I also get shift knocks with 91 and none with 100.....
Offline Gary Wells
« Reply #38 on: December 30 2005, 07:11:16 AM »
Whose chip are you running, and what's it set at for timing?
« Reply #39 on: December 30 2005, 10:34:55 AM »
Sounds like the timing is set too high for that shitty 91 octane.
Offline ledzeppac
« Reply #40 on: December 30 2005, 11:40:31 AM »
Neal Steward chip.....   most likely 17 degrees like yours Gary....
Also,  Now I'm getting tons of knock when reved in nuetral... like 33 wtf.....
But in Gear rpms dont go over 4000....
Most likey due to running really rich, I hope.
Offline sun dog
« Reply #41 on: December 30 2005, 11:53:06 AM »
I need to sneak some GM Top Engine cleaner to you guys.  It works miracles if you have a lot of carbon build-up in there.  Could your ESC module be bad and not retarding when it's knocking?  I think they are around $50.  Maybe you could unplug it and see what code you get and see how it runs without it.
Nuke Gay Whales For Jesus
Offline sun dog
« Reply #42 on: December 30 2005, 11:57:16 AM »
If you have a multimeter check your coil pack.  I think it's around 11-13ohms.  My middle coil was bad and I didn't have any symptoms.  Wouldn't hurt to check the wire routing to make sure they didn't get mixed up.
Offline ledzeppac
« Reply #43 on: December 30 2005, 12:00:46 PM »
No coil pack is ok  I have 3 different sets that have been on.
I might want to change the ESC module cuase I did get a code 42 last week for two days and then it went away.
I didnt even know about that little thin until last week.
Watch two years of frustration and its that......
« Reply #44 on: December 30 2005, 12:46:28 PM »
Ever check on your motor mounts and see if they are OK?
