Author Topic: Whats wrong with my car.  (Read 63695 times)
DCEPTCN
  • Guest
« Reply #165 on: February 22 2006, 02:54:17 PM »
Quote from: "Top Speed @ Wed Feb 22, 2006 12:38 pm"
Whats wrong Deception?
« Reply #166 on: February 22 2006, 03:46:53 PM »
lol
Offline ledzeppac
« Reply #167 on: March 02 2006, 07:25:32 PM »
Sweet I dont like cam lobes on my number three exhaust!
Pulled valve covers, yup number three is done.
I'm gonna have Turbo Lou fix it as I cant do it myself....
Offline Recklessrob
« Reply #168 on: March 03 2006, 01:04:36 AM »
Quote from: "ledzeppac @ Thu Mar 02, 2006 7:25 pm"
Has the cam been replaced ? There has been a problem with aftermarket cams
wiping #3 because the lifter bores are a little offset. Enough, that they prevent
the lifters from spinning, and they end up dragging across the cam.
A comp 206 would make an excellent replacement with no adverse effects.
They've since rectified the alignment issue. :supz:
Rob
Offline ledzeppac
« Reply #169 on: March 03 2006, 03:14:16 AM »
Quote from: "Recklessrob @ Thu Mar 02, 2006 10:04 pm"
No its the stock cam... but I did replace the valve springs in the summer and I'm sure the seat pressure did the trick.... I do have a stock profile cam that Neal Steward bought for me... I think Wells makes it or Weller or something...
I think I am going to go with one of Lou's jsut so he can garantee the parts... as he said he can only garantee the labor with 'my" cam...  I'll talk to him tomorrow...
Offline 87natty
« Reply #170 on: March 03 2006, 03:45:39 AM »
Good luck bud. What I'm worried about is where all them cam shavings went. You don't need pieces of cam floating around your oil system. I'd tear it all down, but that's just me. I have a daily driver too, but I wouldn't risk the new cam or motor. Good luck.
Offline ledzeppac
« Reply #171 on: March 03 2006, 07:45:37 AM »
I know me too and Lou stressed that also... so Lou's gonna drop the pan and check the bearings and whiles hes there redue the rear main seal... so we are hoping that since I change my oil every 3 that most of it got caught up in the oil filter and we are good to go.
Offline ledzeppac
« Reply #172 on: March 03 2006, 05:44:41 PM »
Car is at Lou's....  lets see how it goes
Offline Recklessrob
Re: Whats wrong with my car.
« Reply #173 on: March 04 2006, 12:06:21 AM »
I agree with you on letting Lou supply the cam. We use the
anology of "bringing your own meat to Mc Donalds".
Can you cook this for me ? Don't blame us if you get sick...
The most susceptable component is probably the turbo itself.
If debris got in there it won't last long.  :mad:
Rob
Offline ledzeppac
« Reply #174 on: March 04 2006, 01:59:34 AM »
welll fuck I forgot about the turbo... thats a new unit too just about 3 months old.... if that thing goes bad I will be so fucking pissed.
And I did bring my own meat to Lou... He said lets just use the cam you have as it looks good.
I left it up to him... he made the choice.. ill live with it
Offline 87natty
« Reply #175 on: March 04 2006, 06:26:21 PM »
Ask him how big you can go and still pass the sniffer test.
Offline Recklessrob
« Reply #176 on: March 05 2006, 01:15:22 AM »
Ask Lou about checking the center section of your turbo, or what
his opinion is.
Rob
