Author Topic: Caspers Headlight Brightener  (Read 49918 times)
Re: Caspers Headlight Brightener
« Reply #45 on: October 27 2011, 02:33:08 PM »
Okay, I went back to post 32 above and added some corrections/modifcations/and links
Thanks to turbojd for having the patience to help me figure it out!
« Reply #46 on: October 27 2011, 03:12:41 PM »
Curious, this Bi-Xenon:
« Reply #47 on: October 27 2011, 03:14:14 PM »
Offline turbojd
« Reply #48 on: October 27 2011, 03:16:54 PM »
Great! If you have anymore questions, just let them fly Steve!
1987 GN 3" ATR downpipe,PTE TA 49 turbo, adj. wastegate,adj. fpr. Art Carr shift kit 2 1/2" Hooker ex. 3" Hi flow gutted cat, aero chamber muffs. 9"K&N filter, 60/65lb. mototron injectors,heads pocket ported, 3 angle valve job, LT1 valve springs, 340 walbro fp.hot wired, plenum spacer, 160 therm.
« Reply #49 on: October 27 2011, 06:17:51 PM »
Wiring for a single beam D2S should be simple...will have to see what I get and what cutting and soldering I have to do, I guess.
Offline turbojd
« Reply #50 on: October 27 2011, 06:36:48 PM »
I didn't have to solder anything, the relay harness connectors are all "plug in" as well as the ballasts. One connector from the relay harness snaps into the ballast + and -. The other ballast wires then snap into the hid bulb connectors. Run the (red) wire from the relay to battery positive, then run the 2 black wires to ground.
« Reply #51 on: October 27 2011, 07:45:49 PM »
will have to have a look at what is in the box, but, I figured there would have to be some cutting required to trigger the relay from the original wiring
« Reply #52 on: October 27 2011, 08:19:15 PM »
Can one of you add some pics please?
« Reply #53 on: October 27 2011, 08:39:45 PM »
You should be able to pop a spade terminal into the correct old headlight connector position for the relay?
« Reply #54 on: October 27 2011, 09:32:37 PM »
Rather do it a bit better than that....:)
Charlie, once all the stuff arrives, I can put some pics together
Offline turbojd
« Reply #55 on: October 28 2011, 06:04:31 AM »
You could do it that way, but since I used a hid relay harness, the harness has a 2 prong male connector that you just plug into your stock harness. All I had to do was move one of the prongs on the harness to match the stock headlight harness pinout.( The tan wire on the headlight wire is lowbeam) this is what you will need to plug into, and of course a (ground)
« Reply #56 on: October 28 2011, 09:39:13 AM »
Yep, I figured something would have to be moved but that part is relatively easy.  I will rig for a test and if I like the pattern and the light then I will do it right.
It is strange to me that no where have I found a simple how to do it posted as you have laid it out here.  I guess it is so simple that no one thinks there are dummies out there like me that need the abc approach :D
Offline turbojd
« Reply #57 on: October 28 2011, 11:00:12 AM »
Steve, if you order from DDM tuning like I did, don't be alarmed on the shipping time it takes to receive them. When I ordered mine about a month ago it took about 10 days for me to receive the hid kit. From my understanding they have a warehouse in California, and one in China. Mine was shipped out of China, then it went through customs in New York, so it was about 10 days. Just giving you a heads up!
« Reply #58 on: October 28 2011, 11:44:42 AM »
I did...and I appreciate it!
« Reply #59 on: October 28 2011, 01:44:14 PM »
It is kinda amazing that this isn't posted some where in detail, but that's how people make money off of this stuff. Diagrams and pics are good and will help in the long run to make this work better. Thanks Steve.
