I am still confused on the bulbs. The Caspers site says the glare shield is for stock D2S or D2R bulbs and will not fit others. The DMM site sells kits but does not mention shields or if the bulbs are "stock" or what they fit other than they are for H4 housing. I sent them a note and asked...Their bulbs are a heckuva lot cheaper than stock listings I find. It is all JD's fault for telling us how easy it is! lol
OK, JD, got another question... Will the relay harness they sell support two lights?it appears to me that the DMM ballasts only pull a max of six amps as opposed to the 50--100 amp claims I have seen when the lights are being fired up.Did not see a bi xenon lamp in the D2S section. I have seen a few pics where the ground was not lit up up when switched to Highs, but, I have also seen some where it did appear light was still on the ground while on Highs.I would guess that if you installed D2S bulbs in the highbeam housing and aimed them higher and wired so that two low beam lights and two high beams came on when kicking up to High beams, that would solve all problems. As I said earlier, I hardly ever get to use Highs for any prolonged period, any way
I have the kit installed in my car...I didn't notice a difference, but other people with TRs did. Same thing for those power window motors and wiring harness upgrade I've got, I didn't notice a difference with those either but other people were amazed at how "fast" they are now.
