Author Topic: Caspers Headlight Brightener  (Read 49955 times)
Offline turbojd
Re: Caspers Headlight Brightener
« Reply #120 on: December 26 2011, 06:59:20 AM »
oops. sorry about that, but I looked at that pic and thats all that was included in mine. as I bought the harness else where  :icon_smile:
1987 GN 3" ATR downpipe,PTE TA 49 turbo, adj. wastegate,adj. fpr. Art Carr shift kit 2 1/2" Hooker ex. 3" Hi flow gutted cat, aero chamber muffs. 9"K&N filter, 60/65lb. mototron injectors,heads pocket ported, 3 angle valve job, LT1 valve springs, 340 walbro fp.hot wired, plenum spacer, 160 therm.
« Reply #121 on: December 26 2011, 09:39:11 AM »
When you look at the kit they clearly show  two pin weatherpack/metripack connectors:
Offline turbojd
« Reply #122 on: December 30 2011, 08:06:20 AM »
Just a hid write up I thought some people would find interesing. http://www.intellexual.net/hid.html
« Reply #123 on: December 30 2011, 10:02:47 AM »
so I guess we should order Phillips or Osram bulbs when the kit bulbs die
Offline turbojd
« Reply #124 on: December 30 2011, 10:09:27 AM »
I'm not to sure about that, those phillips and osram hid bulbs can be expensive! I can probably buy 5 or 6 sets of the cheaper ones compared to one of those. I'm sure some of these bulbs last longer then others tho. I know of people that have been using these lower priced bulbs for over 2 years now without any problems, guess I'll just have to wait and see.
« Reply #125 on: December 30 2011, 10:57:29 AM »
probably last me about ten years since I try not to go out after dark
« Last Edit: January 02 2012, 08:45:19 PM by daveismissing »
« Reply #128 on: January 14 2012, 03:29:31 PM »
Offline turbojd
« Reply #130 on: January 14 2012, 04:02:44 PM »
Thats the harness that I used, but in the picture they're not showing a H4 connector, the picture that you posted above that one is what comes with the H4 relay harness. That looks like a 9006 connector in that pic on the harness they are showing.Make sure you order a harness for a H4 set up!!! :D
Also when I received the harness, I had to open the end of the H4 connector and swap position of two pins to match the " stock headlight connector pinouts". And yes, the "fuse" and 40 amp relay are included!
« Last Edit: January 14 2012, 04:43:00 PM by turbojd »
« Reply #131 on: January 14 2012, 05:06:05 PM »
You need the 9006 connector to power the ballast.
Offline turbojd
« Reply #133 on: January 14 2012, 05:17:14 PM »
Those two weatherpack 2 pin connectors above on that harness, they snap right into the ballast to power them.
Yes, the picture above is the correct H4 harness connector. Nice price to!
« Last Edit: January 14 2012, 05:26:42 PM by turbojd »
« Reply #134 on: January 14 2012, 06:11:25 PM »
Kanadians are far better off with Hong Kong sellers. His shipping is nuts, the other guy was free.
Metripack 150 series as are the so called 9005/6 connectors.
I'm beginning to suspect with a "digital" ballast stock wiring gauges maybe close to adequate.
