The Bastard Child Buick Board
Look at the lumens output vs voltage on the chart under Why Install Relayshttp://www.danielsternlighting.com/tech/relays/relays.htmlNow, we have to remember that lumens does not always appear as obvious due to the quality of reflector surrounding the bulb but there is still a significant improvement
I just took my silverstars out of the GN and installed a hid kit, what a difference in light. I used the 165mm rectangular e- code housings from Autopal, I then used an H4 adapter glare shield fitted with D2s bulbs in the H4 housing. I also used a relay harness to supply full voltage to the ballasts on startup, and to take the load off of the stock wiring. I also used the D2s 6000k bulbs. Just make sure your headlights are aimed correct and you will not have glare with this setup, mine look great!
Quote from: turbojd on October 25 2011, 08:38:06 AMI just took my silverstars out of the GN and installed a hid kit, what a difference in light. I used the 165mm rectangular e- code housings from Autopal, I then used an H4 adapter glare shield fitted with D2s bulbs in the H4 housing. I also used a relay harness to supply full voltage to the ballasts on startup, and to take the load off of the stock wiring. I also used the D2s 6000k bulbs. Just make sure your headlights are aimed correct and you will not have glare with this setup, mine look great!nice! what did the HID setup cost you?
