Quick question
2
Topic: Quick question (Read 7526 times)
phil_long
F47
...far from avg
Quick question
October 05 2011, 06:51:59 PM »
I removed the digital dash from the car. Now how do I get the whole cluster out so i can get to the back of it to clean it? Thanks in advance
phil_long
F47
...far from avg
Re: Quick question
October 06 2011, 02:20:30 PM »
ummm, hello?
Re: Quick question
October 06 2011, 03:44:31 PM »
never pulled a digital dash...are you saying you removed the entire dash from the car and now you want to remove the cluster?
Normally, you pop the trim in front of the cluster out, then remove the screws holding the cluster to the dash, unclip the speedo cable and pull the cluster out to where you can disconnect the wiring harness.
phil_long
F47
...far from avg
Re: Quick question
October 06 2011, 04:41:06 PM »
I know its confusing, but i pulled the digital dash, and now I want to remove the side lights, etc. So basically I'm trying to pull the whole cluster. Do I have to drop the steering wheel in order to get to the back, or is there another way?
Pyro6
PSI: 2
Re: Quick question
October 06 2011, 06:04:17 PM »
It's a little confusing what you're doing. If you just want to take the IPC out, undo the speedometer cable at the back, undo the 4? 1/4 or 9/32 screws and the digital portion comes out. It sounds like you have the bezel and trim out already.
Re: Quick question
Reply #5 on:
October 06 2011, 08:07:54 PM »
You have to be able to reach up from the bottom and grab the speedo cable where it clips to the speedometer.
that means you have to take the underdash cover off so you can reach up. If I recall correctly, it may give you a bit more room to pull the cluster out if you do drop the steering column down by removing the two nuts that hold it up
phil_long
F47
...far from avg
Re: Quick question
Reply #6 on:
October 07 2011, 08:53:16 AM »
OK, that what I needed to know. And yes, cluster and Bezel already removed. I never knew it was called an IPC. Thanks
Re: Quick question
Reply #7 on:
October 07 2011, 10:00:11 AM »
Me, either. That sounds like something one takes for a bad stomach.
phil_long
F47
...far from avg
Re: Quick question
Reply #8 on:
October 09 2011, 07:39:35 PM »
Alright guys, so now that I removed everything and call myself cleaning the contacts, I put the damn dash back in and the alternator doesn't charge. I've been reading this guide from casper's explaining the special VOLTS bulb, but my car never had one. How important is that resistor within that bulb???
phil_long
F47
...far from avg
Re: Quick question
Reply #9 on:
October 09 2011, 07:44:57 PM »
And I've tried different bulbs across the same location on the flex board, and sometimes there is continuity, and some bulbs there none. only weird thing is, all the bulbs work.....
gbsean
Turbo Street Modified
PSI: 1
Re: Quick question
Reply #10 on:
October 09 2011, 08:29:57 PM »
check the contacts where bulb plugs in..
Re: Quick question
Reply #11 on:
October 09 2011, 08:34:48 PM »
it needs a bulb or a resistor...if the bulb will not light, then the alternator will not charge and even if you have one of the bases with the resistor in it, it will still not charge because the bulb will burn if it is making contact, and if it does not, then the resistor is not making contact either....
You can take a small bulb and a socket and connect it between the alternator wire and a switched power feed and do the same thing...or you can stick a resistor in the wire instead of the bulb and do the same thing.
John sells that field fix that does just that.
phil_long
F47
...far from avg
Re: Quick question
Reply #12 on:
October 10 2011, 03:34:29 PM »
Thanks steve. I thought about investing in the part that John sells. It's inexpensive and it seems like it would do the trick. Just wanted to try and fix something on my own for once. Looks like that's my next purchase......
Re: Quick question
Reply #13 on:
October 10 2011, 08:07:02 PM »
they are tricky to get to make contact. Usually, if you keep messing with it, it will eventually work
phil_long
F47
...far from avg
Re: Quick question
Reply #14 on:
October 10 2011, 08:43:18 PM »
They are definitely tricky. Got the right bulb in there, and it worked properly. I had to use all of my strength to push the dash in to make contact. The screws wont be good enough for a consistent contact, due to vibration etc, so it's looking like I'm going to be purchasing that part. Thanks for all the input guys.
2
Quick question
