Author Topic: Front Brake Upgrade Suggestions Needed  (Read 22098 times)
« on: September 21 2011, 07:05:42 PM »
Time for a front brake upgrade...need a little more stopping power. Gotta be plug-n-play...cuz I'm an idiot. Dual piston front calipers? Different master cylinder? All suggestions welcome.
Re: Front Brake Upgrade Suggestions Needed
« Reply #1 on: September 21 2011, 07:31:28 PM »
What brake system do you have now? PM? Vacuum?
« Reply #2 on: September 21 2011, 07:35:17 PM »
Vacuum-SS Braided Russel Lines-S-10 Rear Wheel Cylinders-All Long Pads-Aluminum Rear Drums
« Reply #3 on: September 21 2011, 07:45:26 PM »
I don't think you need to go to dual piston calipers, they aren't cheap. I would think a good set of slotted/drilled rotors and some great pads should work better. Maybe change to Hydroboost.
What's the primary use? Cruising? Autocross? Drag?
« Reply #4 on: September 21 2011, 07:54:17 PM »
Drag. I'm not worried of the price of dual piston calipers.
« Reply #5 on: September 21 2011, 07:59:18 PM »
Well, that's easy then. Have you looked at Baer upgrades?
« Reply #6 on: September 21 2011, 08:13:11 PM »
Nope...waiting for you guys to point me in the right direction. I run stock GN rims...and TTA rims...so they have to fit over the new calipers. SSBC another choice?
« Reply #7 on: September 21 2011, 09:11:31 PM »
Dual piston is cheap if you look around and it's plug and play. 98-02 S-10 Blazer 4 door 2WD have an 11" rotor and dual piston caliper brakes that will fit inside stock wheels and can be found in a junkyard. Direct bolt on and all you'll need to do is have the car aligned aftewards. The only drawback is that you have hub bearing assemblies instead of normal wheel bearings.
« Reply #8 on: September 21 2011, 09:57:31 PM »
Baer 12" discs front and rear.
« Reply #9 on: September 21 2011, 11:16:40 PM »
I would use the EBC slotted and dimpled rotors and the yellowstuff pads
Offline gordyzx9r
  • The Sultan of Swank
« Reply #10 on: September 22 2011, 01:02:53 PM »
I think the only issue with the Baer is clearance issues depending on what kind of wheel you use.
I like the stock appearance so I still have stock GN wheels up front and widened GN wheels out back...because of that I went with SSBC brakes up front, aluminum drums and S10 brakes* out back.
*I don't think Steve likes the S10 brake conversion  :tongue ...it's gonna get us all killed.
« Reply #11 on: September 22 2011, 01:30:11 PM »
I think the issue is the S10 cylinders and large, soft rear brake shoes is street driving and panic stops.
That, and people not getting an adjustable proportioning valve.
« Reply #12 on: September 22 2011, 02:57:53 PM »
doesn't take a panic stop on a wet street...parti cularly one that has not gotten wet enuf to wash the oil off...just a light touch can cause the the rear tires to lock and once that happens...bad things come shortly thereafter
« Reply #13 on: September 22 2011, 03:36:23 PM »
That is what used to call a bootleggers turn. Not exactly bad, but if you have never done one of those at speed it could be VERY scary. :-0
AJ___
« Reply #14 on: September 22 2011, 03:48:26 PM »
How did this go from a front brake upgrade to a discussion on rear brakes? He wants to upgrade the front brakes first I thought. Get the fronts to stop better and then the car will stop better. If he wants to do the back later then he can.
