Nasty Wendy Isn't
I'm gonna powder coat it, so finish doesn't need to be nice. no dents, bends, or other than stock holes drilled. also need the 2 fan bolts and washer/nuts that screw into the side of it. thanks
I want to powdercoat at home. Not sure where I would stick an old oven in my already cramped garage though..
Quote from: SuperSix on September 21 2011, 10:00:55 AMI want to powdercoat at home. Not sure where I would stick an old oven in my already cramped garage though..Problem #2 is if you start powder coating (powercoating if yer doin' red rims) you pretty much need to gear up for sandblasting too.
Quote from: daveismissing on September 21 2011, 12:27:30 PMQuote from: SuperSix on September 21 2011, 10:00:55 AMI want to powdercoat at home. Not sure where I would stick an old oven in my already cramped garage though..Problem #2 is if you start powder coating (powercoating if yer doin' red rims) you pretty much need to gear up for sandblasting too.Yeah - that's the suck part. I would need a new compressor for that. i have a ~8 year old 20gal oilless Craftsman.. Nowhere near the CFM I need for blasting.
I was looking at soda blasters, cheap from Harbor Freight. They need like 8-11CFM @ 90PSI, that's a somewhat beefy compressor, ~$500.00 +Northern Tool has some decent IR for about that, can't justify it right now. i need a welder first.
Quote from: tb3 on September 21 2011, 08:25:34 AMI'm gonna powder coat it, so finish doesn't need to be nice. no dents, bends, or other than stock holes drilled. also need the 2 fan bolts and washer/nuts that screw into the side of it. thanksIf you weren't on the left coast I would give you one.AJ___
