Author Topic: 6262 Billet Journal Bearing Results  (Read 4421 times)
« on: September 10 2011, 11:53:00 PM »
Allright. I promised you guys real world results from this turbo...so here they are. Track prep was horrid tonite...as you can see by my short time. After this run I went over and talked to the "big tire" guys...and the best short times they could muster were 1.6-1.7's...so I didn't bother to make another run. 02's were 768...and boost was 20 PSI.
RT-.545
60 Foot-2.072
1/8th-7.867
1/8 MPH-94.29
1/4 ET-12.050
1/4 Mile MPH-117
I crunched the numbers for torque convertor slippage-12.6%
« Last Edit: September 10 2011, 11:57:46 PM by Scoob »
Re: 6262 Billet Journal Bearing Results
« Reply #1 on: September 10 2011, 11:53:42 PM »
Almost forgot. I left Erics chip on the default settings for this run.
« Last Edit: September 11 2011, 12:00:39 AM by Scoob »
« Reply #2 on: September 11 2011, 12:12:00 AM »
That's about 11.4 on a 1.6 short time.  For 20 psi, I think we can say the turbo is working.   I think you done good as they say in certain areas
« Reply #3 on: September 11 2011, 12:18:19 AM »
You running 28" tires on the back?
« Reply #4 on: September 11 2011, 12:19:52 AM »
28X9 MT slicks
« Reply #5 on: September 11 2011, 12:26:10 AM »
I never thought much of the MT slicks, but...they should work...the longer foot print seems to work better than the shorter and wider
« Reply #6 on: September 11 2011, 09:35:07 AM »
Tire prices are absolutely stupid up here. I'm constantly checking Kijiji for 28" slicks. Like to try a different brand...but like they say...beggars can't be choosers.
« Reply #7 on: September 11 2011, 09:36:10 AM »
with modern drag radials, I think slicks are pretty close to obsolete
« Reply #8 on: September 11 2011, 09:42:36 AM »
I agree...but the price for those up here is prohibitive.
Offline Turbocharged Six
  • Newbie
« Reply #9 on: September 24 2011, 09:12:19 AM »
That's about what you should expect for 20 PSI...A better 60 ft and boost 23 to 25 will put you on the door step of tens...If I was confident I have my boost creep under control I'd go to the track and try out my 6262...
