Welcome to IHADAV8.com!
Checked the line off fuel pressure at the track Saturday and it was down two pounds...secon d time this has happened this year. I've got the fuel pressure gauge mounted on the hood but it was hard to see exactly what it was reading going down the track(vibration). Anyway, is this a sign that the pump is weakening? If not...what would be causing this? I was showing 1.2 KR at the top of the track...02's were 808 at 20 PSI. All other SM numbers are normal.
808 is usually pretty rich. The drop in pressure could be the gauge being affected by the temperature, a tired gauge, the regulator, or maybe the pump. Unless you have an expensive, high tolerance gauge, they can often be plus/minus 10%. I would keep my eye on it and the 02s and see if you see a correlation between the two if there is more change.
