No shims...The front bumper was adjusted all the way down...The radiator core support hardware was put in the wrong way...
Quote from: gordyzx9r on November 22 2011, 08:25:16 PMNo shims...The front bumper was adjusted all the way down...The radiator core support hardware was put in the wrong way...Glad you found the problem... Can you repair the damaged fillers?
Quote from: SuperSix on November 22 2011, 09:37:25 PMQuote from: gordyzx9r on November 22 2011, 08:25:16 PMNo shims...The front bumper was adjusted all the way down...The radiator core support hardware was put in the wrong way...Glad you found the problem... Can you repair the damaged fillers?I ordered a new set of GM fronts from NOS4GN. Will get them sprayed and put them on. In the meantime, while the motor is out he's going to pull off the front bumper, take off the damaged ones, and take out the radiator shroud so we can mount the GNS shroud. I'll take the damaged ones and have them stripped and sprayed white for the white car.
