Author Topic: Exhaust Valves  (Read 3845 times)
Offline melrob94
  • Newbie
Exhaust Valves
« on: August 24 2011, 12:23:48 AM »
Are there any stock replacement exhaust valves without the oil pushing ridge on the shaft.  Looking to use valve seals, already had the guide machined.
Thanks.
Rob.
87 WE4,TE44,3\"DP&EXHAUST,204-214 CAM,TRW FORGED,RJC POWERPLATE,RJC BOOST CONTROLLER,42LB INJECTORS&TT CHIP,HOTWIRED 340M,ACCUFAB FPR,METH INJECTION,F-BODY RADIATOR
Re: Exhaust Valves
« Reply #2 on: August 24 2011, 10:00:35 AM »
Nice.. Not too expensive either. Thanks Earl
Offline melrob94
  • Newbie
Re: Exhaust Valves
« Reply #3 on: August 24 2011, 10:28:47 AM »
Thank you.
Re: Exhaust Valves
« Reply #4 on: August 24 2011, 10:31:54 AM »
Thank you.
Stick around melrob - ask questions!
Re: Exhaust Valves
« Reply #5 on: August 27 2011, 03:26:32 PM »
They're actually very nice valves too. Get a slight compression increase, and better flow as well.
