Author Topic: Tint removal  (Read 6402 times)
Tint removal
« on: August 21 2011, 09:12:06 PM »
OK so what is the best way to remove bad tint on the rear window without destroying the heater element.
Looks like it has been there for a long time and has bubbled etc.
AJ___
Re: Tint removal
« Reply #1 on: August 21 2011, 09:27:49 PM »
The gentleman that removed mine had a full blown gas mask on...so whatever the crap is...ain't good for your lungs.
Re: Tint removal
« Reply #2 on: August 21 2011, 10:05:42 PM »
Ammonia softens it IRCC. Heat gun helps too
Re: Tint removal
« Reply #3 on: August 21 2011, 10:55:37 PM »
I was going to say a carefully used heat gun. As for the removal of any residue, I'm not sure. Interested though..
Re: Tint removal
« Reply #4 on: August 22 2011, 12:09:42 AM »
I think I used lacquer thinner for the glue residue after I warmed the film with a hairdryer and got the glue to release. Door glass.
NO idea what thinner would do to the glue holding the foil.
Offline TWIN86GNS
  • My car is almost ready!!!!
Re: Tint removal
« Reply #5 on: August 27 2011, 08:55:00 PM »
A big fukkin hammer always gets the tint off properly.   :add_wegbrech:
It is a bit expensive, but it is worth it in the end.  I am relatively serious with this post as well.  Either use a BFH or take it somewhere and pay to have it removed.  I am cheap and it is worth paying someone to remove it.
Paul Beal
beal_paul@yahoo.ca
Offline gbsean
Re: Tint removal
« Reply #6 on: August 27 2011, 09:27:41 PM »
remove as much as you can physically use a good automotive adhesive remover for residue...it takes time but you will not damage rear defogger
Re: Tint removal
« Reply #7 on: August 28 2011, 09:17:54 AM »
I have left one of mine sitting out while I have been working on the Challenger.  I see the tint is removing itself-rolling up from the edges
Re: Tint removal
« Reply #8 on: August 28 2011, 09:20:45 AM »
Thanks for the tips - I need to remove the old tint from the 87 T and the wife's Integra.
Offline Nasty Wendy
  • Turbo Street Stock
Re: Tint removal
« Reply #9 on: August 29 2011, 12:33:36 AM »
Sean Ryder posted this link somewhere else.  He said this was the stuff to get for the tint glue removal.
http://www.autotechmfg.com/tipsTricks.html
Offline gbsean
Re: Tint removal
« Reply #10 on: September 09 2011, 07:28:21 PM »
holy crap....forgot about that
Re: Tint removal
« Reply #11 on: September 09 2011, 07:37:18 PM »
Heck Sean your not even old yet.
Thanks Wendy
Will be giving it a try next weekend.
AJ___
Offline turbojd
Re: Tint removal
« Reply #12 on: October 26 2011, 10:33:54 AM »
X2, I used a hairdryer to heat the tint up good, nice sharp new blades, and start peeling in a corner, followed by more heat! I also used lacquer thinner to clean up the glue residue left behind. I chose not to retint it myself, I took it to a tint shop.
1987 GN 3" ATR downpipe,PTE TA 49 turbo, adj. wastegate,adj. fpr. Art Carr shift kit 2 1/2" Hooker ex. 3" Hi flow gutted cat, aero chamber muffs. 9"K&N filter, 60/65lb. mototron injectors,heads pocket ported, 3 angle valve job, LT1 valve springs, 340 walbro fp.hot wired, plenum spacer, 160 therm.
Re: Tint removal
« Reply #13 on: October 31 2011, 11:40:34 AM »
Do you have rear defrost?
Offline turbojd
Re: Tint removal
« Reply #14 on: October 31 2011, 04:34:28 PM »
Yes I do, I get the tint good and hot at one side, start at a corner and peel as a continue heating the tint. If your lucky like I was, it'll mostly peel off in a nice big chunk. What ever was left behind I use a razor very carefully around the defroster lines.Then I clean it up with lacquer thinner or rubbing alcohol.
