The Bastard Child Buick Board
Engine Oil Pan
Topic: Engine Oil Pan (Read 2302 times)
ttipe
VOLUMETRIC EFFICIENCY NUT CASE
Bone Stock
Boost n00b
Engine Oil Pan
August 09 2011, 04:28:17 PM »
I'm in the process of installing a poly mount at the drivers side engine mount position.I was wondering if someone had used the engine oil pan to support the engine weight (a board will be placed on a floor jack to displace the weight across the bottom of the pan) to perform this job.My concern is that I don't really know how strong the stock pan is and perhaps someone has done this before.Of course the engine is in the car.Any insite is greatly appreciated.
SuperSix
Administrator
PSI: 234
Re: Engine Oil Pan
August 09 2011, 04:32:51 PM »
So you want to put a jack under the oil pan to lift the motor enough to put the new mounts in? I have never had an issue doing that - I used a 2x4 to distribute the weight a bit.
There will be more informed replies, but it worked for me.
ttipe
Bone Stock
Boost n00b
Re: Engine Oil Pan
August 09 2011, 05:04:56 PM »
Awesome.Thank you very much.
SuperSix
Administrator
PSI: 234
Re: Engine Oil Pan
August 09 2011, 05:21:35 PM »
I *think* I remember using 2 jacks, one in the front and one in the back, to distribute the load and make it possible to cant the motor a bit, but I can't remember exactly.
unlike Bill Clinton, I *did* inhale.
Engine Oil Pan
