Author Topic: Another head gasket thread  (Read 23048 times)
Re: Another head gasket thread
« Reply #15 on: August 07 2011, 01:52:06 PM »
PM is working...as far as I know...and...y ou've got issues.
« Reply #16 on: August 08 2011, 11:45:47 AM »
Try the RJC. I have used a few sets of Victors & they are good gaskets but the RJC will take a bit more punishment & with all the goop on them they seal up pretty good. Get 2 heat guns & while on the stand you can heat cycle the heads one at a time for the retorque per instal instructions.
« Reply #17 on: August 08 2011, 01:51:20 PM »
How do you heat cycle the heads with a heat gun? Unless it has a BTU rating on par with Godzilla
« Reply #18 on: August 08 2011, 02:16:27 PM »
Our plan is to finish the season with the new gaskets and retorque them over the winter. I think the Canadian heat lights are more powerful than U.S., that' how he gets it done.
« Reply #19 on: August 08 2011, 05:04:44 PM »
Canadian Heat Gun
« Reply #20 on: August 08 2011, 05:36:08 PM »
« Reply #21 on: August 08 2011, 06:30:35 PM »
Zackly, that's what I mean. Dave, yours needs plugged in.
« Reply #22 on: August 08 2011, 09:24:09 PM »
I think Ed's runs on beans and burritos.
« Reply #23 on: August 08 2011, 09:32:08 PM »
Ed - I remember reading that one uses 2 heat guns, one per coolant passage in the front of the block. How many hours do you have to have them running?
« Reply #24 on: August 09 2011, 11:09:32 AM »
Just got back from machine shop. Was thinking just resurface headers but too many cracks at existing welds, I just as soon replace them. I am totally lost on whose headers to use. I'm thinking stainless steel, but best flow and sealing is my main concern. Steve, we decided to use Cometics. I talked to Cometics Rep at Chryslers at Carlisle and like what he had to say, but I am also worried about your coolant leak concerns. What made up my was the fact that both steel shim and Cometics should have the same surface prep.
« Reply #25 on: August 09 2011, 11:15:34 AM »
No reason to use anything but stock for headers. Some have had good luck with the Chinese eBay headers.
« Reply #26 on: August 09 2011, 03:17:34 PM »
they are great hgs if they work.
Shims, we glue them on...no leaks
Cometics are made to use without glue...but, I see people using copper coat, opening the layers and spraying stuff in between, etc...let us know how they work
« Reply #27 on: August 09 2011, 04:49:47 PM »
I'll let you know Steve. It's a tough decision and any of the suggested gaskets could go either way. I'm already missing a race this weekend, I would prefer to keep the wrenching part for the winter.
« Reply #28 on: August 09 2011, 05:01:09 PM »
[/quote] But don't you think I could gain a little more HP with other headers??? (mot Chinese) I was looking at Kirban's and Cotton's.
« Reply #29 on: August 09 2011, 05:03:12 PM »
[/quote]
I am FAR from an expert - but after all these years reading TR threads - I have heard that there's very little gain, if any, by using aftermarket headers. Unless you want to try for 9 second quarter miles.
I seem to remember that stockers are good to low 10's?
