Author Topic: Another head gasket thread  (Read 23039 times)
« on: August 06 2011, 04:38:16 PM »
Just got back from Maple Grove. A weekend cut short by a blown head gasket. This is the 2nd time I blew the compression ring at #6. It sounds like a spark plug blew out of it's bore. I use the OEM GM gaskets. I think I'm gonna try the Cometics this time. I was also wondering about switching to roller cam setup while it's apart. I'm gonna look at the lifter and cam wear real close. The damn thing was running so good. I practiced Friday night Grudge racing. I ran an 11.56 @ 116mph, right where I wanna be. I think I'm going to try to drink thru this one.
Re: Another head gasket thread
« Reply #1 on: August 06 2011, 05:17:06 PM »
as said before, read all the magic tricks to make the cometics not leak water...then be sure the block and the heads are ground, not milled, to a 50 or better ra finish
« Reply #2 on: August 06 2011, 06:01:42 PM »
I can do the heads but not the block. I thought it was wierd that this is the 2nd time we blew out the gasket where it leaked external compression. Was thinking all the struggling we did last year started the whole process. Was wondering how many other people leaked external compression instead of on the coolant side? The last time I got GM gaskets I was told they're all gone. I have one left. Fel-Pro?????
« Last Edit: August 06 2011, 06:07:35 PM by Pyro6 »
« Reply #3 on: August 06 2011, 09:17:55 PM »
Well you could always go with the steel shims from Jason. RJC seem to have a good replacement.
« Reply #4 on: August 06 2011, 09:51:13 PM »
I think the key for the cometics is the surface prep - have you had the heads decked?
I have been researching head gaskets - I think the Victor Reinz are the same as the GM. (Did you tell me that, Steve?)  Seems a good amount of people have issues with the FelPro 9441T.
« Reply #5 on: August 06 2011, 10:04:03 PM »
Yeah...altho I have always used a single shim...if I were going composite, I would use Victors
Several have reported problems with the FP's in the last couple of years...
No matter what, both block and heads must be flat.
An eleven second car should not pop gaskets...of course, one bad injector, or one bad spot on head or block changes everything
« Reply #6 on: August 06 2011, 11:06:41 PM »
I find it curious it's always #6?
« Reply #7 on: August 07 2011, 01:18:10 AM »
reason I mentioned an injector or a bad spot
« Reply #8 on: August 07 2011, 08:59:13 AM »
What is a "Bad spot"?
« Reply #9 on: August 07 2011, 09:50:23 AM »
High, low, eroded by exhaust flame, rough, bolt hole threads pulled up....like a bad spot, you know?  :D
« Reply #10 on: August 07 2011, 09:54:29 AM »
Well, I do now!
:D
« Reply #11 on: August 07 2011, 11:48:16 AM »
Just bout ready to pull the intake. The heads were new Champions when I assembled the engine, the block was prepped at a reputable machine shop. I was also wondering about proper head torque procedures. Once you use anything but factory gaskets, would the torque procedure be different? So I'm thinking: get away from composite gaskets. While I have it apart, my headers are about beat. Any recommendation s?
« Reply #12 on: August 07 2011, 12:38:15 PM »
Norbs has gone low 10's with stock ported headers...not sure how fast you wanna go. Nothin' wrong with the stockers...jus t gotta find someone who really knows how to weld. I take all our customers to Norbs for welding...he can weld with da' best of 'em...and we've never had one crack from him yet. Make sure you bolt 'em to an old head or a thick piece of steel before welding...ot they'll turn into a pretzel.
« Reply #13 on: August 07 2011, 12:43:51 PM »
I've only used stock and 9441PT head gaskets...so I can't help you about Cometics or RJC's.
« Reply #14 on: August 07 2011, 01:20:42 PM »
Is Norb's your girlfriend or something?
I attempted to PM you but you have it blocked so I asked the question here.
AJ___
