Author Topic: Type II coilpack  (Read 7313 times)
Type II coilpack
« on: August 02 2011, 12:18:51 AM »
What was the issue with using them (3 coil units)?
Baseplate is drilled differently?
Re: Type II coilpack
« Reply #1 on: August 02 2011, 08:01:53 AM »
I forget - but I have one on the the 87 T.
« Reply #2 on: August 02 2011, 08:27:31 AM »
I believe an adaptor plate is required.
« Reply #3 on: August 02 2011, 08:48:49 AM »
They often don't work worth a damn at higher rpm/boost.  They only have one voltage feed instead of two.
« Reply #4 on: August 02 2011, 10:36:37 AM »
Hmm too bad- have one on hand.
Maybe I'm barking up the wrong tree, here's my symptoms:
Car seems fine otherwise , no codes,
highway driving-periodically above ~2200 it ....bogs hesitates.
backoff the throttle a bit and it clears up.
I do see a bit of black deposit on the lower quarters at the tailpipe.
Thoughts?
« Reply #5 on: August 02 2011, 11:06:56 AM »
what does your pl log show under these conditions?  Does not sound like an ignition problem.
« Reply #6 on: August 02 2011, 11:18:07 AM »
Fuel pressure?
« Reply #7 on: August 02 2011, 11:55:31 AM »
I guess you guys are forcing my hand to get a PL.
So I wouldn't necessarily see retard if fuel disappeared?
This is the car with the new DW pump ( installed by ArizonaGN )
« Reply #8 on: August 02 2011, 12:30:36 PM »
I guess that would depend on how much boost.
« Reply #9 on: August 02 2011, 02:17:41 PM »
I understood you said it happened at cruise.  Doubt you are running boost at cruise...but.. .if you have alky, quickly tap the test button and see if picks up
« Reply #10 on: August 02 2011, 03:43:30 PM »
You are correct Sir!
Alas pure stock, white as the virgin snow....
http://www.dtekk.com/cars/Quik621.jpg
« Reply #11 on: August 02 2011, 04:05:45 PM »
if you had powerlogger, it would be easy to see if the o2s fell at this time which would be indicative of lack of fuel, but, even with a scanmaster you can watch them and see if they change at this time.
« Reply #12 on: August 02 2011, 06:22:05 PM »
Get a PL, Dave
« Reply #13 on: August 02 2011, 07:18:19 PM »
also...crank it up, unplug the cam sensor and go drive it...see if that changes anything
« Reply #14 on: August 02 2011, 08:50:16 PM »
Thanks Steve. I'll do that and report
