Thanks. I plan to do just that with the cooler. Did you use both the stock and aftermarket cooler?I was thinking running the fluid Trans > OEM radiator cooler > B&M plate > trans.
Quote from: SuperSix on August 01 2011, 08:25:28 AMThanks. I plan to do just that with the cooler. Did you use both the stock and aftermarket cooler?I was thinking running the fluid Trans > OEM radiator cooler > B&M plate > trans.Go straight to the external cooler...two reasons. Do you really want all that shit sitting in the trans portion of the cooler to get pumped into your new trans when you fire it up? How clogged up and wore out is the trans cooler portion...so how much cooling is it really gonna do? I run a trans temp gauge in my car cuz I'm trashing on it at the track on a regular basis...and it stays as cool as a cucumber with the external cooler.
Got call from the tranny guy today - not good.Apparently the guy that rebuilt it last time was a moron - no names will be given. (This is my spars trans, not the one that came on the GN I just bought)They used nuts to load the accumulator, only installed 1/2 of a 10 vane kit, it was missing a governor spring, direct drum is trashed (because of the accumulator/nut combo) they had used JBWeld to secure the wiring harness/plug to the case, I put MAYBE 2k on the trans and the band is done - they weren't Altos like I paid for, etc and so forth. It's getting a modified Trans Go kit, new pomp, direct drum, billet forward drum shaft assembly from Scott McClay, rollerized park gear, rollerized low/reverse clutch housing, Alto red clutches, some Borg parts, and all the standard replacement parts.Going to run me about 1500 total, seems fair to me.Still pissed about getting fucked on the first rebuild - but it was a long time ago, time to move on.
Quote from: SuperSix on August 02 2011, 10:41:48 PMGot call from the tranny guy today - not good.Apparently the guy that rebuilt it last time was a moron - no names will be given. (This is my spars trans, not the one that came on the GN I just bought)They used nuts to load the accumulator, only installed 1/2 of a 10 vane kit, it was missing a governor spring, direct drum is trashed (because of the accumulator/nut combo) they had used JBWeld to secure the wiring harness/plug to the case, I put MAYBE 2k on the trans and the band is done - they weren't Altos like I paid for, etc and so forth. It's getting a modified Trans Go kit, new pomp, direct drum, billet forward drum shaft assembly from Scott McClay, rollerized park gear, rollerized low/reverse clutch housing, Alto red clutches, some Borg parts, and all the standard replacement parts.Going to run me about 1500 total, seems fair to me.Still pissed about getting fucked on the first rebuild - but it was a long time ago, time to move on.Sounds like what happened when I bought Norbs transmission.. .and this was no fault of Norbs. The shop that built it for Norbs originally fucked up large. When I had my tranny guy take it apart to freshen it up...the other place had screwed up so much stuff inside that I had to get another 200 trans from Norbs that he had laying around to use for parts.
I agree with Scoob fwiw. When I do trans coolers for customers that tow, I bypass the rad and go with a bigger cooler than what I think it needs. I always felt it was better to eliminate the 200 degrees the coolant contributes.
Steve from Pat's emailed me back - $200.00 plus shipping to restall the converter. Again.. Wheeeeeeeeeeee eee (That's the sound of my wallet getting thinner)
