Author Topic: Software change completed!  (Read 10951 times)
« on: July 26 2011, 10:24:23 PM »
Welcome to IHADAV8.com v2  8)
There's still much to do, we lost a few posts that were made after I migrated the database - but all should be fine.
All avatars, signatures, and posts made it. Please visit your Account Profile page and update your info, as birth dates, and some other small details didn't transfer over.
Yes, change is hard - but I think if you look this over, you will enjoy it, and I don't have to worry so much about getting hacked.
Multiple themes now work, you can choose your theme in your profile. This is the default, but there's two others if they are more pleasing. Attachments should work now too, I am tweaking that now.
I will be adding mods, and smilies quickly, but the base functionality is here and working.
V2 will eventually be moved to a faster database server - that should help all the way around.
Please PM or email me if you need any help or have concerns. supersix@ihadav8.com.
Thanks for your patience
Mark
Re: Software change completed!
« Reply #1 on: July 26 2011, 10:29:39 PM »
Where the fuck is the SHOUT BOX???!!!
« Reply #2 on: July 26 2011, 10:30:58 PM »
Patience grasshopper. I am working on that....
« Reply #3 on: July 26 2011, 10:34:54 PM »
X2
« Reply #4 on: July 26 2011, 10:35:50 PM »
It's the end of the world!
« Reply #5 on: July 26 2011, 10:40:27 PM »
I had no choice mang - that software package I had before was REALLY old, and modified to the point where it couldn't be upgraded, it was a HUGE security risk. 90% of the mods that it did have were useless, and no longer supported. This one has a lot of cool features - give it a shot.
« Reply #6 on: July 27 2011, 10:36:42 AM »
Getting used to it Mark, but it's just enough different to have to figure it out.
« Reply #7 on: July 27 2011, 10:42:03 AM »
Thanks Charlie..
It will grow on you.  I am adding functionality like crazy.
I do miss the look of the old one - hell, I have had it up for almost 8 years.
I need to make a post up of all the features, and ease of use, that may help with the transition.
« Reply #8 on: July 27 2011, 11:03:23 AM »
Thanks Charlie..
Well get on that RIGHT now. lol
AJ___
« Reply #9 on: July 27 2011, 06:41:12 PM »
No, problem.  I was just joking.  Change is good!
Offline Texas Turbo T
  • Don't Mess with Texas ! ! !
« Reply #10 on: July 28 2011, 07:52:29 AM »
Careful, sites UNDER CONSTRUCTION ! ! !
« Reply #11 on: July 28 2011, 04:57:09 PM »
Great job Mark.
Just a few things.
No edit in the posts.
Cookies do not seem to work when you use the see latest post to put you to where you last read, it puts you at the beginning of the post.
I guess this is as good a place as any to make the little things known.
AJ___
« Reply #12 on: July 28 2011, 04:58:45 PM »
Thanks - I will check that stuff out ASAP>
