Author Topic: Dodge Caravan Exhaust help  (Read 5550 times)
Offline chrisgarrett
« on: July 10 2011, 08:00:33 PM »
Hi guys.  I left, but I didn't get very far.  I need help.
I replaced the exhaust on my Dodge Caravan with the exact same parts, nothing added, nothing missing. The kit I'm using looks exactly like the stuff I took off.  The bolts have a shoulder on them and only go so tight.  The lead gasket is loose in there, even though I can't make this any tighter.  Anyone familiar with this setup?
« Reply #1 on: July 10 2011, 08:51:56 PM »
Chris, should the flange on the end of the new pipe slip over the shoulders of the bolts so that the springs can pull it down against the donut?
Only other thing I could see is that the donut is too small, but, it looks to me like the holes in the flange should be reamed out
Re: Dodge Caravan Exhaust help
« Reply #2 on: July 10 2011, 09:21:56 PM »
Steve, the bolts slip right through the holes in the flange.  The shoulder on the bolt is at the rusty manifold piece.  All of the pieces, including the gasket are identical to what I took off and there was no leak at this point.
« Reply #3 on: July 10 2011, 09:25:27 PM »
If you put a couple of washers over each bolt before installing them, will that pull the donut back into the recess more?
« Reply #4 on: July 10 2011, 09:28:46 PM »
still the old donut?
« Reply #5 on: July 10 2011, 09:33:45 PM »
That's what I was thinking, but why did the last piece fit without washers?  Here's the old pieces which are identical to the new.  I keep thinking I'll have a head-slap moment :shrug:
« Reply #6 on: July 10 2011, 09:37:16 PM »
It's a new donut.  I tried putting it both ways, but it clearly tapers into the manifold.
« Reply #7 on: July 10 2011, 09:38:12 PM »
The donut is metal.  Looks like lead.
« Reply #8 on: July 10 2011, 09:46:31 PM »
yeah...only thing I can think of is the donut is a bit smaller...or the springs or a hair shorter, or the new bolts a hair longer...I would think some washers would shim the assembly tighter
« Reply #9 on: July 10 2011, 09:47:34 PM »
maybe, you mixed up the parts with the original gn dp parts :D
« Reply #10 on: July 10 2011, 10:04:54 PM »
Yeah, thanks Steve.  I'll try some washers tomorrow.  Hope all is well with you and yours.
« Reply #11 on: July 10 2011, 10:18:26 PM »
still hate cars, it still has not rained, and I am cranky as ever, so I am the same as always...I am still looking for metal under the bondo of this damn Challenger and it is beginning to irritate me.
Hope all is good with you, too :)
« Reply #12 on: July 11 2011, 08:21:19 AM »
Check the bolts side by side for shoulder length, failing that,or if any other parts aren't exactly the same side by side - use 1/8 > 1/4" of shims/washers under the bolt head.
« Reply #13 on: July 12 2011, 02:02:11 AM »
Quote from: "chrisgarrett @ Sun 10 Jul, 2011 19:37"
It's a new donut.
