HighWay Stars
Author Topic: Let's see how ROck Auto handles this  (Read 3541 times)
« on: July 01 2011, 04:10:35 PM »
My email to them:
Hello.
I received the shipment with the 1pc MK7326 in it. The part that came was used, and I believe the wrong model.
1st - It's red, according to Mevotech's site it should be blue. http://partsonline.mevotech.com/Showdetails.aspx?pn=MK7326
2nd - it has "7327" molded into the side. (The box is labeled correctly) According to Mevotech's site - this is for a 1 5/16 sway bar - I need one for a 1 1/4, like the MK7326 I ordered, See pics, click link for full size
3rd - The box and received mount was greasy - See pics, click link for full size
Also - your description says:
MEVOTECH Part # MK7326  {#K7326} Package Quantity As Shown In Image
Category: Stabilizer Bar Bushing
But I only got one bushing and bracket - was I suppose to receive 2? I need 2 total. How do we resolve this?
HUGE pic links:
http://www.ihadav8.com/images/DSC01156.jpg
http://www.ihadav8.com/images/DSC01157.jpg
Thanks
Mark
Re: Let's see how ROck Auto handles this
« Reply #1 on: July 01 2011, 06:34:39 PM »
Most excellent. I have noticed that they never admit that there was an issue with them selling returned merchandise - this is 2 times now. At least they take care of it.
Dear Mark,
Thank you for the email with the pictures.  I'm sorry to hear that you received a mis-boxed item.  I have setup a reshipment of the correct part for you.  We will not require you to send back the incorrect part at this time but I do ask that you hold onto it for two weeks in case our warehouse requests a return.  If you have any further questions please respond to this email or give us a call at the toll-free number below.
Thank you,
Adam B.
RockAuto Customer Service
Offline gbsean
« Reply #2 on: July 01 2011, 07:35:39 PM »
hey they took care of it..it happens...
« Reply #3 on: July 01 2011, 07:54:14 PM »
I'm glad I don't have to send the wrong part back.
Offline hiboom
« Reply #4 on: July 01 2011, 07:55:18 PM »
well you had better luck than i did ordered power steering pump was one of there close outs no core required about 65.00 when it arrived it looked like someone had installed it or it was a core return.i emailed them about it they asured me it would be fine.I took off a better one then the one from rock auto did not work at all.No replacement on close out parts.
« Reply #5 on: July 01 2011, 09:05:16 PM »
Hmm.. I never knew that about closeout parts - I buy them when I can.
Here's a link to closeouts for the GN.
http://www.rockauto.com/RSS/vehiclefeeds.php?carcode=1020957&m=wc&l=en&html=true
SOme really wrong parts in there. :)
« Reply #6 on: July 01 2011, 09:09:35 PM »
Parts ordered recently from Rock for the GN:
DAYCO 5060635 Belt
STANDARD MOTOR PRODUCTS GV16 PCV Grommet
"ACDELCO   252582 Water Pump"
"ACDELCO   2173414 Fuel Rail O-Ring Kit"
"ANCHOR   2379   Transmission Mount"
"ATP   SO35 (SO-35)   Dipstick Seal"
"FEL-PRO   35608   Thermostat Housing Gasket"
"FEL-PRO   129961 Water Pump Gasket"
"FOUR SEASONS   84994   Thermostat Housing / Water Outlet"
"NATIONAL   8610   Differential Pinion Seal"
"STANT   10331   Radiator Cap"
R43TS Spark Plugs
MEVOTECH Stabilizer Bar Bushing set
STANDARD MOTOR PRODUCTS SK27 Fuel Rail O-Ring Kit
STANDARD MOTOR PRODUCTS SK26 Fuel Rail O-Ring Kit
DORMAN 65202 Oil Drain Plug
FEL-PRO ES70599 Fuel Injector O-Rings
FEL-PRO ES72697 Turbocharger Gasket
MEVOTECH MK8988 Stabilizer Bar Links
VICTOR REINZ MS15958 Intake Manifold Gasket
VICTOR REINZ G30951 Throttle Body Gasket
VICTOR REINZ P27857 Differential Cover Gasket
VICTOR REINZ VS39763R Valve Cover Gaskets
« Reply #7 on: July 01 2011, 09:51:37 PM »
Quote from: "SuperSix @ Fri 01 Jul, 2011 19:05"
Not really Mark, just the wrong year after all. :bigeyes;  :rofl;
Thanks for the link BTW. I needed to order some parts for mine. :supz:
« Reply #8 on: July 01 2011, 10:21:28 PM »
Quote from: "Charlief1 @ Fri Jul 01, 2011 8:51 pm"
« Reply #9 on: July 02 2011, 08:44:15 PM »
I've stopped buying ancient discontinued Buick parts. Now I just look for newer more complex parts to replace them with...
Less swindling going on than that NOS-elitist bullshit when I do it this way.
