No code?
do you have a tilt column? if it is loose, any little bump can cause the rod that goes from the key cylinder to the ignition switch to bump the switchslightly out of the "run" position just enough to kil lthe engine. i used to have an 87 Caprice cop car that would do that- it about scared the crap outta me the fiirst time i hit a bump going around a tight turn and the engine died and i lost my power steering.. the fix is to pull the steering wheel, lock plate, and turn signal switch and get in there with a torx bit and some blue loctite and tighten the screws that hold the top part of the column down. easy half hour fix if you have the proper tools and some patience.
Mike...just my 2 cents. You won't sell your car...cuz it's too complicated... even if you demod it. Here's proof. You know how simple my car is. To the general public...it isn't. Had my car up for sale...here's what happened each time. A perspective buyer shows up. As soon as I mention it has an adjustable chip and alky...they go screaming into the nite. I made the decision to race the car with the guys out here in eastern Ontario when we can get together...cuz I'm sure as hell not giving it away. Keep road racing your car when time permits. One of these days your children won't have time for mom and dad...and you'll be glad you kept the car.
Somebody will want it. Patience is a virtue but persistence to the point of success is a blessing. Car looks good!
