Zap *STILL* wears Depends
What vendor told you that?
I guess it is a good thing I am not making 600hp yet. 425 if I am lucky.
Quote from: motorhead on September 13 2012, 11:18:12 PMI guess it is a good thing I am not making 600hp yet. 425 if I am lucky.I must missed something,i read the first post about your build,Less the i guess bonestock motor an 3:08's,everything else you have should of put you in low 11's...60's series turbo an 83lbsr's on Alky an the rest the additive's an only 12's? With Bonestock motor,still under dealer factory warrenty, i bolted on one 150hp NOS kit an ran 11.99@119 with tall L60 McCeary's,stock chip,19-20psi on NOS. With all your mods an money spent,an aftermarket ECM good investment (only about $3000 an plug right in, in less then hour!) ,Love you ride by the way, in the cornering photo's it's Tight, no slag..Enjoy!
My car Suspenionaly set-up as well,Aerospace Prostreet Disk brakes all round (9" in the back) BMR full set control arms upper/lower front rear,Q1A's custom rated coil over all around,28mm rear sway,22mm front adjustable on hime joints,Urethane bushing in frame an All suspension components ,less a Bronze Bushing in upper rear passenger side A-Arm bushing (They melt due to downpipes),all frame bracing including the weld in on the rear lower's with 16 gauge steel rearseat firewall (to save my a-pillar from cracking my paint) It's lowerd 1 1/2" in front an 2" in the rear running 295/40-18's in back an 255/40-18 in front Falken Anzenis r615's 8^) I fire it up again for first time next week (knocking on wood) the builds in the central FL section,motors a whole other story...;^) Enjoy!
Quote from: Hellobozos on September 14 2012, 05:42:53 PMMy car Suspenionaly set-up as well,Aerospace Prostreet Disk brakes all round (9" in the back) BMR full set control arms upper/lower front rear,Q1A's custom rated coil over all around,28mm rear sway,22mm front adjustable on hime joints,Urethane bushing in frame an All suspension components ,less a Bronze Bushing in upper rear passenger side A-Arm bushing (They melt due to downpipes),all frame bracing including the weld in on the rear lower's with 16 gauge steel rearseat firewall (to save my a-pillar from cracking my paint) It's lowerd 1 1/2" in front an 2" in the rear running 295/40-18's in back an 255/40-18 in front Falken Anzenis r615's 8^) I fire it up again for first time next week (knocking on wood) the builds in the central FL section,motors a whole other story...;^) Enjoy!Um... okay. But, why are you plugging your car in my thread? I mean there is a certain irony in this given I created this thread to avoid doing the same to others... but, still I find it a little odd. And believe it or not I am well aware of your car and the "money spent". I am just not sure if in this dick measuring contest I want to pull mine all the way out or not?
