Author Topic: Valve adjustment  (Read 4423 times)
Offline chrisgarrett
Valve adjustment
« on: May 29 2011, 12:32:08 AM »
I have a roller cam with adjustable rockers.  I want to quiet things down a bit. What should I set the preload to?
Valve adjustment
« Reply #1 on: May 29 2011, 01:06:46 AM »
are these the lifters that are supposed to be set at .003" or the other variety that take a conventional preload?
I doubt that adjustment will do much, if anything, tho
Re: Valve adjustment
« Reply #2 on: May 29 2011, 07:55:15 AM »
These are T&D rockers.  I guess what I'm asking is, willl more preload quiet them down?  Right now they are set at .025.  Do you think .030 or .032 will quiet them or make them worse.
Valve adjustment
« Reply #3 on: May 29 2011, 09:55:27 AM »
It is the lifter design that determines preload so you must know how much preload the lifter requires.
Comp has one lifter that is designed to run at basically zero preload-.003", I believe.
The other runs at a more conventional preload...some thing like .020"-,040".
Knowing which lifter you have is the starting point.
In the second case, it should not be sensitive to the the setting, particularly at your current preloads.
With adjustable rockers, it is easy if you know the thread count of the ajuster.  For instance, 20 tpi means that one complete turn is .050".
So you know that a half turn to three quarter turn after zero preload is a good range.
If they are 25 tpi, then one complete turn is .040"
Roller cams are like conventional flat tappets in that the lobe ramp design makes some cams a bit more tickety than others.
I believe that I just said I doubt it will make any difference if you have the second type of lifter.
« Reply #4 on: May 29 2011, 11:19:03 AM »
Thanks Steve.
Valve adjustment
« Reply #5 on: May 29 2011, 07:39:00 PM »
Also adj. rockers are for fine tuning. I would not go more than .020 either way. If you need to get longer or shorter pushrods.....
