If you ordered the Comp Cam lifters...you mite find 'em a tad noisy. What brand is the 208/208 cam FT sells?
Got the needed parts ordered. I thought I had everything, I don't.Ordered a 208/208 cam, lifters and Rollmaster timing chain from Full Throttle SPeed.Ordered GM head gaskets and front crank seal from NOS4GNOrdered motor mounts and front cover gasket set from Rock AutoI had purchased a NOS GM front cover, after Earl told me mine was Chinese shit, I am off to port and prep that today.
Quote from: SuperSix on November 29 2011, 04:12:07 PMQuote from: SuperSix on November 26 2011, 10:09:33 AMGot the needed parts ordered. I thought I had everything, I don't.Ordered a 208/208 cam, lifters and Rollmaster timing chain from Full Throttle SPeed.Ordered GM head gaskets and front crank seal from NOS4GNOrdered motor mounts and front cover gasket set from Rock AutoI had purchased a NOS GM front cover, after Earl told me mine was Chinese shit, I am off to port and prep that today.Got the front cover ported - Pics below. Seems there was some sort of booster plate on the motor - I can't ID it. I don't want to use it, per earl and Steve's recommendation - but that means I now have to source shorter bolts for the housing. Anyone know who made this?Porting pics:Got the front cover ported - Pics below. Seems there was some sort of booster plate on the motor - I can't ID it. I don't want to use it, per earl and Steve's recommendation - but that means I now have to source shorter bolts for the housing. Anyone know who made this?Porting pics:
You need (5) 1/4-20 X 1" and (1) 1/4-20 X 1-1-1/2.And of course, there's a trick. You'll noticed the long bolts you have are small headed bolts with a built in washer. A normal 1/4 bolt will have a head too big to actuate with a wrench or a socket.or you could just get one of my pimp ass SS socket head cap screw timing cover kits and be done with it
It's all about the pimp, Charlie
