Author Topic: New 87 GN (Topic merged with "It's On!" post)  (Read 137840 times)
Re: New 87 GN (Topic merged with "It's On!" post)
« Reply #345 on: August 12 2017, 07:54:22 PM »
Okay, I was worried there for a second.
« Reply #346 on: August 12 2017, 08:01:28 PM »
Once I get this one dialed in, a d get myself familiar with PowerLogger, and the Scanmaster G I just ordered, I plan on upgrading the turbo and intercooler first. That's a ways away.
« Reply #347 on: August 12 2017, 08:04:16 PM »
The 200's won't take much abuse over stock HP levels. Be prepared to throw money at the trans when you upgrade the IC and turbo.
« Reply #348 on: August 12 2017, 10:13:38 PM »
Its a Cruz or White trans already IIRC
« Reply #349 on: August 12 2017, 10:22:10 PM »
Yes - it's fully rebuilt.
« Reply #350 on: August 12 2017, 10:29:00 PM »
Yer' good to go...put the boost to 'er!
« Reply #351 on: August 12 2017, 11:45:08 PM »
Did I read that tranny invoice correctly? $11k for a rebuild?
« Reply #352 on: August 13 2017, 08:25:25 AM »
Typo, sorry. All in, Scott McCClay drum, etc - $1750...
« Reply #353 on: August 13 2017, 08:44:42 AM »
What convertor is in the car? What size exhaust housing on the turbo? I'll assume .63 Garrett. I'm to lazy to go through this post.
« Reply #354 on: August 13 2017, 09:48:18 AM »
PTC 2800 10" lock up.. Not sure on the exhaust housing.
« Reply #355 on: August 13 2017, 10:53:14 AM »
It'll spool well with that convertor with a .63 Garrett.
« Reply #356 on: August 13 2017, 11:02:26 AM »
For a cheap instant upgrade I'd weld a Dutt neck to the stock IC.
« Reply #357 on: August 13 2017, 11:06:10 AM »
Thanks, good idea...
« Reply #358 on: August 13 2017, 03:47:31 PM »
Yah, nearly sh*t myself reading that. :O
« Reply #359 on: August 14 2017, 10:19:01 AM »
Good and bad wrenching day yesterday.
Used yet more rivet nuts, this time for the chassis ground next to the battery. Replaced a through-bolt I had installed for grounds. (Fan harness, and battery > chassis ground) Finalized battery cable routing. Used another rivet nut for the battery hold down, no more body clip/retainer. Had to re-tap the shitty side post extender I need for the Ramchargers fan, and power tap.. I may need to rethink that approach, or buy a better post extender.
Decided to install the new Highway Stars A/C lines, close up the A/C system, and put a vacuum on it. Removed the seal from the back of my new compressor, it still had a vacuum, that's a good thing.
Glen's lines include a small aluminum adapter/bushing that has to be used with the new-style A/C compressors. I read that, read up on it, says it's required, but not how or where to install it. Process of elimination brought me to the thought that it fit in the outer discharge port.
I went to see if it fit, so I could understand the item's use. I wasn't paying attention, and tried to put it in the suction port, and it quickly fell into the bowels of the R4 compressor. Yay.
Used my borescope, couldn't see the part.. Soooo time to take the compressor out. Lots of fun.
Long story short, after a lot of shaking, more borescope use, brass hammer taps, smacks, etc - the adapter is stuck in the compressor, there goes $250.00 down the tube, the ruined unit was a brand new ACDelco too. I could hear it rattling around once, but couldn't get it to where I could grab it. :013: :013:
Ordered a new compressor, another adapter, and a new high pressure switch from Highway Stars...
This is the item that fell in the compressor, and yes - I am indeed a dumbass.
