Author Topic: New 87 GN (Topic merged with "It's On!" post)  (Read 137853 times)
Re: New 87 GN (Topic merged with "It's On!" post)
« Reply #300 on: September 02 2014, 01:52:26 PM »
ground strap to the frame cannot hurt?  Ground loop in the making!
Sounds like you made some progress!
I thought it would help provide GND for the frame? That's wrong?
« Reply #301 on: September 02 2014, 03:44:06 PM »
The frame is not a ground on a G body
« Reply #302 on: September 02 2014, 05:36:40 PM »
Well then - OK.
Thanks. :)
« Reply #303 on: September 05 2014, 12:01:53 PM »
Getting more and more done.
I have a few rolls of vacuum line coming in today - I will run all new lines this weekend.
Got the FBody radiator installed. I will be surprised if it doesn't leak - looks a bit beat up.  I'm not running an engine oil cooler, so I should be good.
I have the transmission cooler line coming in today too (I had a lot less hose/line than I thought I did - thanks Amazon!)
using that, I will plumb both the internal radiator and external coolers.
I am spending a good amount of time just rounding up loose ends, small parts, fasteners, etc. I guess this happens when you are a bit unorganized, and the work takes longer than you initially expected.
Are Grade8 bolts good enough for the 6 bellhousing bolts?
« Reply #304 on: September 05 2014, 09:16:38 PM »
yep, they should work just fine
« Reply #305 on: September 09 2014, 11:11:17 PM »
Yep..
Coming along...
« Reply #306 on: September 10 2014, 03:48:01 PM »
Looks good S6!
« Reply #307 on: September 10 2014, 03:58:58 PM »
Looking nice under that hood!
« Reply #308 on: September 14 2014, 11:22:04 AM »
Customized Intrepid fan wiring harness for Racetronix dual fan harness.
Completed trans fluid piping. Trans out > filer > radiator > external cooler > trans in
Enclosed and routed + ALT cable, HVAC vac lines, routed gauge harness under manifold (For the most part)
Connected and routed tach lead for 4" (I think) VDO tach I have. I still need to wire the internal gauges, I haven't touched the interior yet, except to replace.repair the existing horn ring - someone got happy with JB Weld and Super Glue, it was all that was holding it together.
Connected and routed nylon boost signal tube, going through a single grommet in the firewall, with the 4 gauges wires.
Verified the engine is at TDC, (Thanks, Steve & Vortexbuicks.c om) checked cam sensor, window is where it should be. I weighed using a standard sensor cap and using the Casper's LED tool I have, or to use the Casper's LED cap I have. It looks like the LED cap is easier to set correctly,so I went with that.
I took the time to clean the timing mark out, and fill it with white crayon wax. I wonder if I should have used paint, and why I didn't do that for the ~2 years the engine was on a stand, but I digress..
I noticed the crank sensor needs adjustment and tightening, and that I hadn't plugged it in.
Prepared, painted, and prepped the sway bar for installation. I will complete it once I have it up in the air for the transmission install. right now, the rear of the engine is being supported by wood blocks.
I need to figure out what size hardware I need to install the Gran Prix braces and front bar I have. Those aren't a great priority though. Anyone have an idea? I haven;t started searching yet..
I think I will do a very detailed check before I fire this thing-It's been so long, I am sure there's a fastener or three I need to tighten/adjust.
I like having the freedom to do what I want with the car, not worry about keeping it pure. I am rerouting, drilling, mounting, and moving shit- having a lot of fun with it too.
Wait until I paint it pepper gray metallic. :P
Some pics coming soon.
Trans hoses/filter - messy, but functional. I put slices of a bike tire tube in most places to insulate from vibration. A used bike tube can be very handy!
Trans piping with new ($59!) FBody radiator - those stupid little fittings were $12 ea. Sheesh. ;)
Intrepid fan after harness mod - Love doing shit like this. Used the ample parts from the Racetronix fan kit - nice new weatherpak connection. The old harness I cut out is on the upper left.
« Last Edit: September 14 2014, 11:27:42 AM by SuperSix »
« Reply #309 on: September 14 2014, 03:44:21 PM »
I like the color!  You are making a lot of progress :)
« Reply #310 on: September 14 2014, 04:21:33 PM »
Be careful of that dual fan setup. Walked by the front of my car one day...and it kicked on and pinned me to the grill. :)
« Reply #311 on: September 14 2014, 05:32:29 PM »
Lol lol!
« Reply #312 on: September 14 2014, 08:10:08 PM »
I had hoped to get it started this weekend, but I had way too much shit to get done.
Maybe this week, but it's coming!!
« Reply #313 on: September 14 2014, 08:15:58 PM »
Take your time. Rushing is never a good idea.
« Reply #314 on: September 15 2014, 09:23:02 AM »
You're right. That's been nagging me too.
