Author Topic: New 87 GN (Topic merged with "It's On!" post)  (Read 137744 times)
Re: New 87 GN (Topic merged with "It's On!" post)
« Reply #255 on: January 29 2013, 04:20:37 PM »
You did replace the old harness with this setup...right?
http://www.racetronix.com/RX-G7-INJ-AB.html
« Reply #256 on: January 29 2013, 04:35:20 PM »
An injector harness? No.
I have the Ractronix FP Hotwire kit too.
« Reply #257 on: April 18 2013, 03:26:20 PM »
Update...
« Reply #258 on: April 18 2013, 03:37:05 PM »
Meh - none really.
I finally got the gas tank done and ready to put in.
Finished tank..
« Reply #259 on: April 21 2013, 05:44:46 PM »
That's a lot of work!  It's looking really nice.  Can't wait to see the final product. :rock:
« Reply #260 on: April 21 2013, 09:44:36 PM »
Thank you sir!
I never promised a pretty car - but she'll be a-ok. ;)
Offline deathraider6996
  • PSI: -1
« Reply #261 on: May 13 2013, 12:04:28 PM »
Lets go dad, get on it!  :rofl:  Waiting for more updates!
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Duttneck Intercooler
3200 Vigilante Converter
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #262 on: May 13 2013, 12:44:09 PM »
Oh shit. Called out by my own son.
« Reply #263 on: May 13 2013, 01:05:06 PM »
 :tongue
Get your arse in gear, the boys waitin' for his own ride!
 :045:
« Reply #264 on: May 13 2013, 01:26:51 PM »
Haha. He has one.. I'm giving him the 87 T in a few years. :)
« Reply #265 on: May 13 2013, 03:30:12 PM »
I think this is called, Outa sight, outa mind!  he does not seem motivated by Buicks anymore!
« Reply #266 on: May 13 2013, 05:43:31 PM »
And He'll probably never get it if you don't finish your Jalopy first.
  • PSI: -1
« Reply #267 on: May 28 2013, 04:38:46 AM »
Please dont say that. Im going crazy waiting. Having to see them everyday and knowing their not mine or that i dont have one of my own...kills me  :( :)
1987 Buick Turbo-T
PT-51
.030 over
Built trans
60 lbs inj
212/212 flat tappet
Alky single nozzle
Walbro 340
Boxed lower rears
Hotchkis Drag Bar
275/60-15 MT DR
« Reply #268 on: July 14 2013, 10:00:04 AM »
Patience grasshopper. :)
Ok, here's the lastest updates on the GN:
I finished putting AN fittings on the trans cooler lines - they are ready.
Removed chrome rear end cover, cleaned off the rust with steel wool and a wire wheel. I spray painted it with clear engine enamel to stop/slow the rust from coming back. Replaced rear end fluid with Lucas synthetic and 1 bottle GM posi additive.
But the DAY I finished servicing the diff - I see the aluminum Buick cover TB3 was selling and buy it. (Thanks man - FAST shipping, great communication!)
I decided to paint it similar to the "theme" of the motor, low gloss black with sanded aluminum ribs.
As received:
Painted (Before sanding/Dremel)
After sanding - done. Casting isn't the greatest - the rib width is screwey down by the bottom.
This is with the old cover on, I just finished the aluminum cover last night. I replaced the shocks too. I was told they were "newer", but remember this car has been sitting for ~6 years. They needed to be replaced.  This is as I was putting the gas tank back in. And if you need to remove tanks/etc on a regular basis. go buy a Harbor Freight transmission jack. It makes dropping the tank a breeze.
http://www.harborfreight.com/automotive-motorcycle/transmission-jacks/450-lb-capacity-transmission-jack-39178.html
New Racetronix sender/hanger, fuel pump, and hot wire kit. (Not installed yet)
Installed:
Next up is rebuilding the rear brakes - I am replacing everything but the backing plates.
« Reply #269 on: July 14 2013, 12:05:58 PM »
Same jack I've got Mark. One other nice thing about it is you can use it as an adjustable seat and move around on it to do things like the brakes you're going to do. Much better than squatting or resting on your knees. :rock:
« Last Edit: July 14 2013, 11:29:00 PM by Charlief1 »
