Zap *STILL* wears Depends
Wait till ya' blow a head gasket(s)...and all your work will go for not. Looks real purdy to this point tho.
I'd dimple those holes in a good 1/4"...and then fill 'em...but not quite flush with premixed fiberglass...s hort strand. Use bondo to fill the last 1/16". Paint it...and you'll never know they were there.
I've never looked close enuf to see if the grommets have sealer around 'em. I'd think they'd fit in snugly and wouldn't need any. Not sure if you can get the gasket or not. Mite check with GBODY or Glen at Highway Stars. Could you not use the old gasket as a template to make a new one?
I also want to reseal the factory grommets for the speedo cable, throttle cable, parking brake cable etc.. I guess I should have done that before I painted around them, I assume that whatever sealant i use would be better on an unpainted surface.Can I just use silicone? Or should I use panel adhesive/seam sealer?
RTV is Radio-TV silicone which is supposed to be non corrosive to electronics.The non RTV Silicones you need to watch out for.Neutral-Cure is best.
