Author Topic: New 87 GN (Topic merged with "It's On!" post)  (Read 137753 times)
Re: New 87 GN (Topic merged with "It's On!" post)
« Reply #165 on: March 25 2012, 10:50:01 AM »
Damn!  that was a lot of work!  I should import you to help me out.  My body is in rebellion after taking the winter off to play Skyrim
Texas has winter?
« Reply #166 on: March 25 2012, 11:26:18 AM »
Your AC condenser looks like it went through WWIII.
« Reply #167 on: March 25 2012, 11:34:38 AM »
Yeah - not sure why I didn't just take it out, I'm getting a new one anyway.
Hitting it with the pressure washer spray didn't help. :p
« Reply #168 on: March 25 2012, 12:57:16 PM »
Texas has winter?
Not much of one this year, but, I like the shop to be at least 65 before I go out...Yesterda y, it was freakin hot
« Reply #169 on: March 25 2012, 06:28:40 PM »
Got more done today..
Removed the A/C condenser and old trans cooler. Cleaned a shit ton of leaves off of the front rubber mat/air guide.
Prepped and painted the PS inside fender. I used an adhesion promoter primer, and the low-gloss black engine enamel I have been using on everything else. Ran out of paint.  :(
Still kind of a test - but I really like the way the low gloss came out. And I see my garage camera's shutters didn't open all the way. Dammit
Here you can see the sheen difference between the low gloss (fender) and semi gloss (core support).
« Reply #170 on: March 25 2012, 07:38:03 PM »
Looks good to me...you gonna have that thing come alive, yet!
« Reply #171 on: March 25 2012, 07:40:08 PM »
Quit being anal...drop the damn engine in.
« Reply #172 on: March 25 2012, 09:41:35 PM »
You said "Anal"
 :tongue
« Reply #173 on: March 25 2012, 09:58:50 PM »
You said "Anal"
 :tongue
Bout time you chimed in.
« Reply #174 on: March 26 2012, 05:40:52 PM »
lol.
I think that the low gloss looks good!
« Reply #175 on: March 27 2012, 09:32:46 PM »
Yeah - but I'll never have this car this much apart, I'm not in any real hurry, and I like tinkering with it. It won't be too much longer before the motor is in - I have a goal, and I'm kind of on schedule. Fuckin mosquitoes and bugs really suck though. I will have a full, enclosed air conditioned garage next house I move to.
Fiddled with it some more the past few nights..
I had a broken relay, where it mounts to the side rail. Nothing a little silicone can't fix.
Painted/cleaned/re-assembled:
Old heatshield I have had kicking around the spare parts pile for many years, I figure it can't hurt:
« Reply #176 on: March 27 2012, 09:49:44 PM »
I clean a little bit more of my engine compartment every time I have the engine out. New exhaust studs and bolts...you've got issues. Keep the pics comin'.
« Reply #177 on: March 27 2012, 09:52:08 PM »
Bah - the exhaust hardware was part of that 79.00 stainless bolt kit I bought.
I do wonder though - when I am wire brushing small screws and painting them.. Haha
« Reply #178 on: March 27 2012, 10:32:23 PM »
Is that what that is supposed to look like? Nice
« Reply #179 on: March 30 2012, 04:04:12 PM »
Yeah - all painted.
Got the fuseable link relocation started - got some marine 10ga wire, snipped off the old fusible links, and extended the wiring. I crimped, soldered, and heat shrunk the connections - should be fine. all 5 power leads will snake around the bottom of the AC/heater box, then to new fusible links, to a junction box, with a master 4ga to the battery.
I need to order the 4ga - may use some to replace the alternator feed too.
I finished up lubing the new front end parts. I threw away both of my Harbor Freight grease guns (they SUCK), picked up a pneumatic Campbell Hausfield for $19.99 shipped. Works like a champ. Still gets air bubbles, but it's easier to bleed the air out.
painted a bunch more crap - it's coming along!
