Author Topic: New 87 GN (Topic merged with "It's On!" post)  (Read 137703 times)
Re: New 87 GN (Topic merged with "It's On!" post)
« Reply #120 on: December 03 2011, 12:39:45 PM »
Those gears look serviceable to you?
« Reply #121 on: December 03 2011, 01:28:07 PM »
You need (5) 1/4-20 X 1" and (1) 1/4-20 X 1-1-1/2.
And of course, there's a trick. You'll noticed the long bolts you have are small headed bolts with a built in washer. A normal 1/4 bolt will have a head too big to actuate with a wrench or a socket.
or you could just get one of my pimp ass SS socket head cap screw timing cover kits and be done with it :)
Is the bolt length indicated the total length? Or just the threaded part to the bolt shoulder?
Either way, I'm pretty sure these are the pump repair bolts - the short ones are 1.459" overall, 1,245" from end to shoulder, and the long one is 1.713 overall, 1.493 to the shoulder.
I guess I could cut these - I doubt I will. I will probably get the Allen head SS ones from Alloy Boltz..
« Reply #122 on: December 03 2011, 01:37:35 PM »
Bolts are measured from the tip of the threaded section to the area where the head and the shaft join together Mark.
« Reply #123 on: December 03 2011, 02:31:27 PM »
I looked at the alloy boltz webpage. I don't think their kits come with the filter adapter bolts.
« Reply #124 on: December 03 2011, 03:37:55 PM »
Mark, can you take a pic of the oil pump cover from the side that covers the gears...I don't have that on my site
« Reply #125 on: December 03 2011, 04:04:44 PM »
The ony excepion being flat heads (countersunk) which are measured end to end (dunno why)
« Reply #126 on: December 03 2011, 04:16:33 PM »
I got them at Home Depot this afternoon, of all places - .82c ea. Stainless Allen head.
I have one of the Alloy Boltz kits, and you are correct, it does not have the oil pump bolts.
I picked up some wet or dry 600grit to do some more work on the lower oil pump housing - is that going to be fine enough?
« Reply #127 on: December 03 2011, 04:17:53 PM »
Like this?
Or this?
« Reply #128 on: December 03 2011, 04:47:12 PM »
thanks...that will do!
« Reply #129 on: December 03 2011, 05:09:12 PM »
New cover, old gears? With the amount of work you are doing, replacing the gears is a good insurance policy. I don't like the wear pattern on the edge of the gears.
Offline The Radius Kid
« Reply #130 on: December 03 2011, 06:15:47 PM »
Those gears are junk.
Get a new set and MAKE SURE you debur the tops and bottoms of the gear teeth.
I believe they're broached and do tend to have a burr due to the cutting process.
« Reply #131 on: December 03 2011, 07:05:27 PM »
I just spent ~30 minutes with it, a can of WD-40, and 2 sheets of 600 wet/dry sandpaper - it looks much better now.
I realized that the bolts need washers - modified 2 washers for the pocket bolts - used regular ones on the other bolts. After putting it all together for a test fit - the gears wouldn't turn - looks like I will need to find a thicker gasket.
You guys are right. The standard Sealed power kit should work?
http://www.jegs.com/i/Sealed+Power/844/224-518/10002/-1#
Odd, Jeg's is almost $5.00 cheaper than Rock Auto...
« Reply #132 on: December 03 2011, 07:27:36 PM »
looks right to me
« Reply #133 on: December 03 2011, 08:08:07 PM »
The cooler adapter feels buttery smooth. Surface looks rough when zoomed in though. :)
« Reply #134 on: December 04 2011, 09:16:41 AM »
Are there reasons you would want to replace that casting?
nos4gn:
