Ok, I think, I may know this one..I think in Picture #2, it looks like those connectors go together. Kind of hard to tell...maybe Cam Sensor?
Quote from: "TSM Girl @ Wed May 04, 2011 8:22 pm"Ok, I think, I may know this one..I think in Picture #2, it looks like those connectors go together. Kind of hard to tell...maybe Cam Sensor? No, the one in question is much smaller that the cam sensor plug, seen towards the bottom. I need to park my 87 T next to it and pop both hoods.
pic 2
You start one step at a time...look at the trees, not the forest.Spending $15 for the shop manual on cd from Jeremy Wood will eliminate your wiring questions as well as give plenty of other help.Being that you have another car, pull it over and check one against the other.....don't forget the ac compressor has a couple of connectors on the back as well as the clutch connector.I would disconnect the fusible links from the starter and pull the harness up around the back of the head so you can get to the effed up spot and fix it....Make sure the ground bundles on the back of the head are in good shape and not pulled loose or corroded.
the light purple single wire is the o2.Here is a tip that might save you grief down the line...make sure the wiring harness behind the drivers side valve cover is supported up in the air.
Mark-Did
