Author Topic: Lean Cruise  (Read 11152 times)
Offline Wrecked Em
    • http://www.hotairbuick.com
Lean Cruise
« on: April 25 2011, 09:36:44 PM »
Anyone using Lean Cruise on their chip? If so, what kind of MPG are you getting?
Lean Cruise
« Reply #1 on: April 25 2011, 10:35:50 PM »
As I am using a speed density chip, I program my own cruise to be around 15.5-1 which is around 020 on the oem o2.   I get around 24-25 on my more moderate car on cruise control at 70
Offline Wrecked Em
Lean Cruise
« Reply #2 on: April 25 2011, 10:40:10 PM »
Quote from: "Steve Wood @ Mon Apr 25, 2011 8:35 pm"
Lean Cruise
« Reply #3 on: April 26 2011, 10:53:56 AM »
I only have experience in modern years with TT chips..make that recent years LOL
but, they kick out of the cruise mode when the lv8 rises to a certain level.  Therefore, if you live in hilly country, the lv8 will rise every time you start up an incline and the car will go for a richer number.  In other words, the best gas mileage  comes where there are few changes in incline.
I used to set my cruise where the oem O2 read a steady 000 on the scanmaster.   This was close to 17-1 on the wb.  When I went to 75# injectors, I came down a bit for fear that the larger injectors might be a bit erratic and low pulse widths and I might have a problem.
In the early days of the MaxEffort, I used to keep removing fuel until I could feel a skip in the engine at 75 mph, then I would add a couple percent back in and call it good.  That always read 000 on the sm.
Pretty soon, someone will come in and inform us that setting the a/f to stochiometric gives the best mileage but I am calling bs in advance of that.  :)
