Author Topic: Shelf Life: Denatured Alcohol with/Uplon Lube?  (Read 3768 times)
Offline gordyzx9r
  • The Sultan of Swank
« on: April 23 2011, 07:13:48 PM »
What is the shelf life of denatured alcohol with Uplon Lube mixed in it?  I thought it would be fairly long but now I'm being told it could be as little as 3 weeks once the seal is broken.
« Reply #1 on: April 23 2011, 08:23:32 PM »
was it resealed....it goes bad from moisture being absorbed into it...if the source is closed off, it should be fine.
Offline gordyzx9r
Re: Shelf Life: Denatured Alcohol with/Uplon Lube?
« Reply #2 on: April 23 2011, 09:11:04 PM »
What about in an alky tank in the car?
« Reply #3 on: April 24 2011, 12:49:05 AM »
that probably was not that well sealed
it will not be bad..it will just be diluted with some water....after all, some run 50-50 and others run straight water....if it does not show timing retard, it is okay
Offline challengermike
« Reply #4 on: April 24 2011, 10:50:14 PM »
While we are talking about this how much lube you guys been adding.I have been using about a cap full of lube per old smc round bottle when i fill it.Im starting to wonder if its not enough,i have been threw 3 pumps now.
Offline gordyzx9r
« Reply #5 on: April 25 2011, 03:46:41 PM »
I use 1 oz per gal. for the past 7 years and I'm still on the same pump.  It's a first generation SMC kit.
« Reply #6 on: April 25 2011, 05:48:49 PM »
I guess thats not my problem then,lol.If anything im over oiling it.
« Reply #7 on: April 25 2011, 05:53:44 PM »
Quote from: "challengermike @ Mon Apr 25, 2011 4:48 pm"
It doesn't sound like a capful would be enough to over oil something. Strange. What brand pump do you keep killing?
« Reply #8 on: April 26 2011, 09:05:26 PM »
Its my fault because i have been throwing regular fuel injection pumps for an s10 or a chevy in there since the orginal one died.I was just wondering if i wasnt putting enough oil in with it.I should just get the correct pump and be done with it.The pumps were free so i cant complain.But it really opened my eyes to hitting the test button before each run to make sure it works.When  the orignal one died and took out the head gaskets.
