Author Topic: front stabilizer bar bracket threads stripped. helicoil?  (Read 16686 times)
Offline tb3
Re: front stabilizer bar bracket threads stripped. helicoil?
« Reply #30 on: April 23 2011, 11:24:08 AM »
heli-coil seems like its gonna do the trick :supz:
I put the almighty torque on it and it held tight.
« Reply #31 on: April 23 2011, 12:40:58 PM »
Wow. GREAT job, looks fantastic.
Offline tb3
« Reply #32 on: April 26 2011, 04:42:47 PM »
thanks!
I need to roll it outside and take a better pic to show detail.
I hope to start on firewall next week :rock:
« Reply #33 on: April 26 2011, 04:58:13 PM »
Quote from: "tb3 @ Tue Apr 26, 2011 3:42 pm"
thanks!
« Reply #34 on: April 26 2011, 08:01:28 PM »
Quote from: "SuperSix @ Sat 23 Apr, 2011 10:40"
Gotta agree with you. Very nicely done. :supz:
« Reply #35 on: April 26 2011, 08:33:57 PM »
Quote from: "SuperSix @ Tue Apr 26, 2011 3:58 pm"
thanks!
...I hope to start on firewall next week :rock:
...pull the motor out of the new GN< and clean/detail the front..
... pulling off the front clip and all.
About the same amount of work, no? (no idea , last clip I pulled was a '72)
Very Pretty TB3.
« Reply #36 on: April 26 2011, 11:08:21 PM »
Quote from: "daveismissing @ Tue Apr 26, 2011 7:33 pm"
thanks!
Very Pretty TB3.
The more I look at it, the more a complete engine removal may be needed for the GN. :(
Offline tb3
« Reply #37 on: May 21 2011, 02:30:25 PM »
holy  sch-moly!  I'm actually doin some work on this thing today   :rock:
supersix,   pulling the front clip is very very easy.  if the engine hoses/wires, etc that connect to fender wells and front are disconnected.. ...  its just 2 or 3 (cant remember) bolts in the door jam, and one on top on each side (keep track of shims).  then unbolt the hoodlatch and driver side of firewall fusebox, then the front two body bolts and the whole thing lifts off in one piece.    easy stuff :rock:
« Reply #38 on: May 21 2011, 07:32:27 PM »
Quote from: "tb3 @ Sat 21 May, 2011 12:30"
holy
Offline tb3
« Reply #39 on: May 21 2011, 09:27:21 PM »
gotta remove the hood and bumper first of course.
glad I'm able to help  :rock:
« Reply #40 on: May 22 2011, 12:07:18 AM »
Quote from: "tb3 @ Sat 21 May, 2011 19:27"
Offline tb3
« Reply #41 on: May 22 2011, 09:42:45 AM »
not a tranny, but if I had a nice set of tits installed l wouldn't leave the house. sure would be alot cheaper in the long run :rolleyes;
« Reply #42 on: May 23 2011, 01:46:25 PM »
Quote from: "tb3 @ Sun May 22, 2011 8:42 am"
http://www.marvelousmanboobs.com/
« Reply #43 on: May 23 2011, 08:00:25 PM »
Anyone that clicks on that link...
« Reply #44 on: May 23 2011, 09:43:39 PM »
I checked the logs, bro. You are a SERIAL clicker.
