Author Topic: Vacuum Block  (Read 4072 times)
Offline Buca
Vacuum Block
« on: April 11 2011, 09:38:45 PM »
Vacuum Block, Who's using them and What are the Advantages and Disadvantages??
Vacuum Block
« Reply #1 on: April 11 2011, 09:54:38 PM »
Do you mean the one that is on top of the doghouse? Not sure what you mean by advantages - I have one because I had to for my vacuum brake conversion.
Vacuum Block
« Reply #2 on: April 11 2011, 09:55:30 PM »
vacuum brakes?
Offline Buca
Re: Vacuum Block
« Reply #3 on: April 11 2011, 10:36:34 PM »
So when I do the Vacuum brake upgrade, I should get a Vacuum block? Just seen it in "Knowledge Base Articles, Submissions, and Comments " Figured it'd be an easy way not to worry about Vacuum leaks is all...........
Vacuum Block
« Reply #4 on: April 11 2011, 10:44:24 PM »
It's the easiest way to get a strong vacuum signal.source. I suppose you could tap into the manifold somewhere else.
It is a spot than can easily leak, you are correct. You can get a new bock and still use the powermaster, you would just have to cap it off.
Offline Buca
Vacuum Block
« Reply #5 on: April 11 2011, 11:00:44 PM »
Quote from: "SuperSix @ Mon Apr 11, 2011 9:44 pm"
Just figured with the Vacuum Block, I'd have one less thing to worry about in the long run....
Vacuum Block
« Reply #6 on: April 12 2011, 09:40:12 AM »
The only difference between the vacuum block used with vacuum brakes and the vacuum block that is standard ont he car is the number of ports built into it.
The one for vacuum brakes has one extra port on the drivers side for the hose to the power booster on the brakes.
Originally, the Turbo Trans Am  had vacuum brakes and we just got a vacuum block for that car.  Then some started making blocks out of aluminum instead of plastic.
Either way, it just makes it easier to connect the booster without having to tap into something else like the pcv hose, or tapping into the intake.
Vacuum Block
« Reply #7 on: April 12 2011, 01:13:27 PM »
here is a picture of an aluminium one on one of my cars
http://www.vortexbuicks-etc.com/tvcable.htm
