Author Topic: Better valve spring  (Read 4058 times)
Offline grand camino
Better valve spring
« on: April 02 2011, 11:21:06 AM »
I'm looking for options other than a comp 980. I posted at the buick site and most are ok with comps.  I read where comps can be, and are, inconsistant.  My 204/214 is 4 years old and quiet. i have always run good oil and ZDDP. I was thinking 100/105 seat pressure would be ok. I like the idea of a GM part, like an LT1 spring ,but now i hear they can sell knock-offs as well.  any suggestions appreciated.
aka"turbocamino" 87 GN motor,trans,rear,dash. TRW+30,balanced crank and rods,max port irons+intake,cometics,212/212-500,HS1.65,6265JB,alkycontrol,stevemon.62mm T/body,JRacing 044-external,TTchips,60Lb.Motrons,RazorAlky,PTC2800L/U, NGK-PLX,GYear ssDR,3"down and out,Airbags
Re: Better valve spring
« Reply #1 on: April 02 2011, 02:51:30 PM »
I'm not sayin a word after what happened last time I voiced my opinion....... .
« Reply #2 on: April 02 2011, 04:59:38 PM »
What are you shifting the car at and what rpms do you cross the traps at? How many miles on the springs?
« Reply #3 on: April 02 2011, 10:46:53 PM »
I'd like to see 5200 but it seems to go flat by 5000. The spring are 4years old.   I'm seeing  high 10's/low 11's on my wideband  during a blast and car runs great. zddp always as well.  Not a drag car...but i do beat up on my friends lightning and mustang now and then.  Kirbans springs seem like a decent choice, yes?
Better valve spring
« Reply #4 on: April 03 2011, 12:30:17 AM »
Personally, I would stick with the 980s which should turn that cam easily past 5200.  I would rather do that than suddenly increase the pressure upward and take a chance on increasing the wear on a cam that has been in the car awhile and settled in...but that is just me
« Reply #5 on: April 03 2011, 06:54:40 AM »
Quote from: "grand camino @ Sat Apr 02, 2011 9:46 pm"
