Author Topic: 1984 TType Drive train upgrade question  (Read 6702 times)
Offline Bob-Lob-Law
« on: April 01 2011, 12:21:01 PM »
My TType is an 84 so in order for me to run the electric fan, I had to use Casper's electronic fan jumper.  Well, when I converted the entire drive train to the 86/87, I installed the Casper's wiring harness but I found that I still have to use the fan jumper as the electronic fan still won't turn on even though the wire harness has the hook up and I'm running an 86/87 ECM.  Do I need to also change the fuse box out in order to not have to use the fan jumper or is there something else I'm missing?  I appreciate any and all help.
« Reply #1 on: April 01 2011, 12:21:57 PM »
Do you have the correct relays in place?
Offline Bob-Lob-Law
« Reply #2 on: April 01 2011, 01:12:30 PM »
All relays are in place and good
Re: 1984 TType Drive train upgrade question
« Reply #4 on: April 01 2011, 01:24:39 PM »
You have the fan turn on sensor that is located on top of the intake in place and wired?
Offline Bob-Lob-Law
« Reply #5 on: April 01 2011, 01:25:26 PM »
Yes, that is what it is, the fan relay kit.  However, I do have the stock 86/87 relays in and connected to the wiring harness.  I just cannot get the fan to run when I plug it into the 86/87 wiring harness.  I have to revert back to the relay kit.
Offline Bob-Lob-Law
« Reply #6 on: April 01 2011, 01:26:38 PM »
Yes sir, the sensor is in an wired.
Offline Bob-Lob-Law
« Reply #7 on: April 01 2011, 01:27:34 PM »
Would one of the relays being bad prevent the fan from running?
« Reply #8 on: April 01 2011, 01:44:38 PM »
Bob, the fan circuits are pretty simple...the 86/87s turn on low by the ecm as per the temp programmed into the chip.  High speed by the ac pressure or water temp.
here is a link from my site  http://www.vortexbuicks-etc.com/fan.htm
It might be simpler to look at the diagram at the bottom than read all my words...I get carried away with the sound of my own keyboard sometimes
Offline Bob-Lob-Law
« Reply #9 on: April 01 2011, 02:03:10 PM »
Steve, thanks for the help, I'll be looking at that this weekend.
Good to "see" you again.
« Reply #10 on: April 01 2011, 02:56:29 PM »
Same here!
