Author Topic: Brad Penn oil  (Read 7685 times)
Brad Penn oil
« Reply #15 on: March 30 2011, 02:28:00 PM »
Quote from: "SuperSix @ Tue Mar 29, 2011 11:23 pm"
Wow. wtf.
lol!!!
Brad Penn oil
« Reply #16 on: March 30 2011, 03:34:40 PM »
What's your oil pressure when hot, and you can hear the tapping?
Re: Brad Penn oil
« Reply #17 on: March 31 2011, 11:15:54 PM »
http://www.autozone.com/autozone/accessories/Tools-Garage-and-Equipment/Automotive-Stethoscope/_/N-26gd
Has a variety of uses.
Or if you are good you can do like the old timers do and us a wooden stick or broom handle to narrow it down or find it.
Not sure Steve on that injector comment, late night?
Cam sensor, lifter?
AJ___
Brad Penn oil
« Reply #18 on: April 01 2011, 09:52:29 AM »
Nope...might be his imagination that oil changed the sound....some injectors are very loud
Brad Penn oil
« Reply #19 on: April 01 2011, 09:54:51 AM »
Most Buicks that I have seen have had some ticking noise from somewhere....I don't pay attention unless it suddenly gets worse or a different sound shows up...no use spending your life wondering if it is a piston pin or windshield wiper bearing
Brad Penn oil
« Reply #20 on: April 01 2011, 11:10:12 AM »
Quote from: "Steve Wood @ Fri Apr 01, 2011 8:54 am"
Agreed
AJ___
Re: Brad Penn oil
« Reply #21 on: April 01 2011, 11:10:57 AM »
Try and run the engine with the Serpentine belt removed. Bad belt or idler pulley can make the same noise.
Re: Brad Penn oil
« Reply #22 on: April 01 2011, 11:14:06 AM »
Oil pressure is good ( 50 warm and crusing) and its not an injector, I know that sound. I did try the long screwdriver trick held to my ear and checking around, no luck. Pulled the valve covers and held my hand on each rocker to see if I could feel anything or hear a change in noise...no luck. I kinda ended up where what Steve said, it just makes some noise and I gotta quit worring about it. Cant wait for the salt to get rained off the roads here so I can get it back out again!!
Want to get rid of the Flowmaster exhaust this spring and get the Pypes cat back system installed.
Thanks alot guys!!!
