Author Topic: Brad Penn oil  (Read 10336 times)
Brad Penn oil
« on: March 29 2011, 01:40:37 PM »
I really liked this stuff but its a huge pain in the ass to get for me. Whats a good substitute, 10W40 prefered.
Thanks!!
Brad Penn oil
« Reply #1 on: March 29 2011, 03:36:55 PM »
What do you like about that brand?
Brad Penn oil
« Reply #2 on: March 29 2011, 04:13:02 PM »
my motor had a loud tick ( no header cracks) and I went from mobil 1 to Valvoline to this stuff and with this the tick seemed to be reduced quite a bit. Maybe its in my head but I hated the ticking and this helped. Just wondered if there was a more readily avaliable oil that might have some of the same properties??
Brad Penn oil
« Reply #3 on: March 29 2011, 04:16:09 PM »
The only thing I think could stop a tick like that would be a thicker viscosity - have you ever tried 15w40? Like a Rotella? From what I can see on the Brad Penn - it's basically a racing oil with high ZDDP
The best solution would be to track down and repair the ticking sound, of course. :)
Re: Brad Penn oil
« Reply #4 on: March 29 2011, 04:34:19 PM »
Find the tick don't mask it.
AJ___
Brad Penn oil
« Reply #5 on: March 29 2011, 05:04:34 PM »
yeah, I've spent 2 years trying to find this tick, Short of taking the whole motor apart I've given up! Thats why I liked this oil. would the heavy ZDDP content help with the ticking. I'm guessing from my reading that on  the # 3 cylinder the cam lobes are worn and its coming from that but I'm probably way off. Its a slight ticking but I'm pretty picky and it bugs me
Re: Brad Penn oil
« Reply #6 on: March 29 2011, 05:50:12 PM »
Did you scope the engine?
Is it cold and warm tick ? Is it louder on start up?
Is it front or back left or right top or bottom?
How many miles on it? Is it a rebuild if so when?
Is the tick a scratchy tick or a tapping tick?
Did it just start to do this or was it a gradual thing.
Just looking to help out.
AJ___
Brad Penn oil
« Reply #7 on: March 29 2011, 07:50:35 PM »
get old and you won't hear ticks
I use Valvoline Racing
Brad Penn oil
« Reply #8 on: March 29 2011, 07:51:34 PM »
you can try royal purple as well
Brad Penn oil
« Reply #9 on: March 29 2011, 08:01:02 PM »
I have Brad Penn in my pickup truck, local mechanic was using it as bulk oil!.
I said WTF!! and told him about the oil. :)
Brad Penn oil
« Reply #10 on: March 29 2011, 08:01:19 PM »
Quote from: "Steve Wood @ Tue Mar 29, 2011 6:50 pm"
Never hear them anyway.
AJ___
Re: Brad Penn oil
« Reply #11 on: March 29 2011, 08:06:00 PM »
Brad Penn oil
« Reply #12 on: March 29 2011, 11:23:05 PM »
Wow. wtf.
Re: Brad Penn oil
« Reply #13 on: March 30 2011, 10:41:30 AM »
Quote from: "$1987 GN$ @ Tue Mar 29, 2011 3:50 pm"
Did you scope the engine? no
Is it cold and warm tick ? Is it louder on start up? warm tick, not loud on start up
Is it front or back left or right top or bottom? hard to tell, middle top???
How many miles on it? Is it a rebuild if so when? 58000 original
Is the tick a scratchy tick or a tapping tick? tapping
Did it just start to do this or was it a gradual thing. done it since I got it 2 years ago
Just looking to help out.  THANKS!!
AJ___
Brad Penn oil
« Reply #14 on: March 30 2011, 02:25:48 PM »
cam sensor?  loud injector?
