Author Topic: Not quite sure...  (Read 10578 times)
Offline gordyzx9r
  • The Sultan of Swank
Re: Not quite sure...
« Reply #15 on: January 29 2011, 11:31:10 PM »
I would stick with the AC Delco brand for ignition modules and coil packs.  Those aftermarket ones do weird shit to a car. Somehow an off brand ignition module found it's way onto my car when it was in someone's "shop" and it caused havoc with my tachometer zeroing out at about 2K RPM.
« Reply #16 on: January 30 2011, 08:19:08 AM »
You can always swap over to a type 2 coil/module setup from fwd 3800 vehicle.
Not quite sure...
« Reply #17 on: January 30 2011, 10:13:36 AM »
given the high rate of bad perfroming type II's I would stay away from them.  They only have one power feed rather than two which sometimes causes them to break up.
I would use a GM module, but, coils don't seem to be as particular.
If you ohm the old coil, it may be bad, but that module did not look too good to me....may have been the picture
Not quite sure...
« Reply #18 on: January 30 2011, 10:35:29 AM »
The early ones 87-93 work great. Later units had troubles. I'm talking about the module not coils.
If one is installed with the proper plate and grounded, failures seem to vanish.
Not quite sure...
« Reply #19 on: January 30 2011, 11:47:11 AM »
I think I will stick to the sure thing
Not quite sure...
« Reply #20 on: January 30 2011, 05:21:18 PM »
Quote from: "ULYCYC @ Sun Jan 30, 2011 10:35 am"
How does one identify the vintage?
Offline Wrecked Em
    • http://www.hotairbuick.com
Not quite sure...
« Reply #21 on: January 30 2011, 05:48:42 PM »
I think if it becomes an issue, i will just convert to a coil on plug system.
Offline Wrecked Em
Not quite sure...
« Reply #22 on: January 30 2011, 05:49:15 PM »
Put 25 miles on the car today. It has been way too long.
Not quite sure...
« Reply #23 on: January 30 2011, 06:02:12 PM »
Quote from: "daveismissing @ Sun Jan 30, 2011 5:21 pm"
Order module delco 1946A or gm pn# 10456478
plate gm pn#10456478
coils are the same up to 2005 (I think) gm pn#10472401
Offline bishir
Not quite sure...
« Reply #24 on: January 30 2011, 06:26:44 PM »
Steve's site will tell you how to ohm them out.  I have a coil pack/module tester and it's a handy dandy tool.  It even helped diagnose and get a turbo-t back on the road on powertour this year. It was a good thing I had brought a spate ignition module with me because even the NAPA crew that follows the tour couldn't locate any nearby for the guy.
