Zap *STILL* wears Depends
Is this bad?
Quote from: "TSM Girl @ Fri Jan 28, 2011 5:46 pm"Is this bad?Nah it looks perfectly fine. AJ___
Quote from: "$1987 GN$ @ January 28th 2011"Quote from: "TSM Girl @ Fri Jan 28, 2011 5:46 pm"Is this bad?Nah it looks perfectly fine. AJ___I do not think so, It is melted.
Quote from: "TSM Girl @ Fri Jan 28, 2011 7:29 pm"Quote from: "$1987 GN$ @ January 28th 2011"Quote from: "TSM Girl @ Fri Jan 28, 2011 5:46 pm"Is this bad?Nah it looks perfectly fine. AJ___I do not think so, It is melted.I am pretty sure that' normal. that's a mastic Motorola put in there to keep the wires from vibrating loose, moving etc.
Quote from: "SuperSix @ Fri Jan 28, 2011 7:01 pm"Quote from: "TSM Girl @ Fri Jan 28, 2011 7:29 pm"Quote from: "$1987 GN$ @ January 28th 2011"Quote from: "TSM Girl @ Fri Jan 28, 2011 5:46 pm"Is this bad?Nah it looks perfectly fine. AJ___I do not think so, It is melted.I am pretty sure that' normal. that's a mastic Motorola put in there to keep the wires from vibrating loose, moving etc.Actually it WAS ok until I opened it up and one of the tabs on the coil broke off from the wire connected to it being stuck in the goo.As a point of reference, the other unit I have is not melted. Maybe different materials since they are different colors.
I have a module but I will need a coil pack to go back on the 85. I borrowed the coil and module from it for now.
Coil packs are 49 at autozone
Quote from: "SuperSix @ Fri Jan 28, 2011 7:04 pm"Coil packs are 49 at autozoneIs that for a re-man? I swear I paid more than that.
