Author Topic: It's ALIVE and KICKIN!  (Read 6369 times)
« Reply #15 on: January 28 2011, 09:05:13 PM »
Quote from: "Wrecked Em @ Fri Jan 28, 2011 8:46 pm"
Well I need to change the water pump and we will be good to go.
Yes, it needs a bath. I can hardly see out the windows.
That's a shit job. No hard, but tedious.
It's leaking?
DCEPTCN
  • Guest
« Reply #16 on: January 28 2011, 09:17:18 PM »
Quote from: "Wrecked Em @ Fri Jan 28, 2011 6:46 pm"
Famous last words of a GN owner.
Have you done the spring cleaning?
Offline Wrecked Em
    • http://www.hotairbuick.com
« Reply #17 on: January 28 2011, 10:15:07 PM »
Quote from: "DCEPTCN @ Fri Jan 28, 2011 8:17 pm"
Water pump is leaking and it is very corroded anyway.
I am doing the winter cleaning.
Cleaned the air filter.
Replaced the plug wires.
Replaced the plugs (went with 42s)
Replaced turbo.
Replaced fuel filter.
Replaced fuel line (rubber hose between line out of tank and line to filter.
Changed the oil.
Replaced power steering fluid.
Replaced radiator support.
Replaced body bushings.
Adjusted TPS.
Adjusted TV Cable.
Adjusted fuel pressure.
Replaced several vacuum lines.
Had wife do half the work. Would have had her do more but somebody has to cook me food and clean the house.
Now to replace the intercooler. Need to get some piping and hoses together.
