Transmissions
converter won't lu
Topic: converter won't lu (Read 11211 times)
poppy1440
Bone Stock
converter won't lu
January 15 2011, 06:26:55 PM »
Hello,
I have a newly installed pro-torque 9.5 lu converter.
I noticed my gas mileage was horrible 8-10 mpg then I noticed my converter was locking up unless I let off the gas a hair. But now I think it is really not going into lu at all. I think the drop in rpms was really just from letting off pedal.
I put a switch to ground pin A and F and put trans in 2nd and drove the car then flipped the switch and nothing. I tested the connection and f is becoming grounded when I flip the switch.
I also unplugged the harness from trans. turned the key to the on position and couldn't get voltage on any of the wires.
I also pushed the brake pedal in and manually pushed in the two buttons on the brake pedal and still nothing.
I notice that on my pl that when I flip the switch I have connecting a and f that the check doesn't come on in the pl in the tcc box. Should it?
What do you guys think might be going on?
Thanks
86 gn. Champion irons, roller cam,stock location stretch intercooler, 3" exhaust," DP, scan master, red Armstrong pump hot wired, 60 lbs injectors, Razors' alky kit, 6265, 6.0 chip, powerlogger, plx-afr, mt 275/50r15 et street
ULYCYC
Turbo Street Modified
PSI: 4
Re: converter won't lu
January 16 2011, 10:59:36 AM »
Appy a 12v jumper to the "A" terminal on the trans. It should lockup when you go into 2nd gear. If it does your trouble is most likely in the command (ECM) or wiring issues. If it don't lock up it could be wiring in the trans, bad seloniod and last a defective converter.
gordyzx9r
The Sultan of Swank
January 16 2011, 12:01:33 PM »
My friend's car was having a problem with locking up, we wound up fixing it when I repaired the wiring to the VSS.
1987 Buick Grand National
poppy1440
Bone Stock
January 16 2011, 07:53:21 PM »
Thanks, I'll start trouble shooting tomorrow
poppy1440
Bone Stock
January 17 2011, 09:25:29 AM »
Goodmorning, This is what I found.
I pulled the brake switch down and checked voltage. I have 12 volts pin b and voltage on pin a and c when I push in the button.
I unplugged to harness going to the trans and I don't have voltage at all. Not with the button in or out with terminal f on adl grounded or not.
What NOw.
______________
____
86 gn. 9" kenne belle air filter, stock location stretch intercooler, 3" exhaust, scan master, walbro 340m hot wired, adjustable wastegate, 60 lbs injectors, Razors' alky kit, adjustable fuel pressure reg, ta49, tt 6.0 chip, powerlogger, plx-afr, mt 275/50r15 et streets. new rebuild back to stock. 2800 pro torqe stall
SuperSix
Administrator
PSI: 234
converter won't lu
Reply #5 on:
January 17 2011, 09:33:49 AM »
Did you do as ULYCYC suggested?
poppy1440
Bone Stock
Reply #6 on:
January 17 2011, 10:09:04 AM »
ok this doesn't make since/
when I checked voltage on pin a at trans. and I didn't have voltage it made me think open circuit had to be my problem so I ran a switched 12v to pin a plugged it back into tran. drove car and turn on switch and still no lock-up. could I be having two separate issues.
poppy1440
Bone Stock
Reply #7 on:
January 17 2011, 10:21:41 AM »
yes I did what ulycyc recomended but the thing that scared me is I had a switch tying terminal a to f on the adl to ground f and when I flipped the switch it started smoking so i immediately disconnected it. I guess I shouldn't have grounded f and jumpered pin a at the trans.
I hope I didn't damage the ecm
poppy1440
Bone Stock
Reply #8 on:
January 17 2011, 11:10:56 AM »
ok i'm half way there. The reason conv. would lu even when a grounded a and f was the top switch was out of adjustment I found this out by taping in closed and I noticed I had 12v on pin a. The problem I have now is that apparently the ecm is not commanding lu. It will only lu if I flip the switch ground a to f. What do ya'll think.
poppy1440
Bone Stock
Reply #9 on:
January 20 2011, 08:52:52 PM »
Update.
The ecm is fried it really smells burnt and here are some pictures
Here's the problem I installed a known good ecm and I have the same result. I have to flip the switch grounding f for the converter to lock. I'm thinking I have a burnt wire also. What do ya'll recommend.
poppy1440
Bone Stock
Reply #10 on:
January 20 2011, 09:05:26 PM »
pics
for some reason when I attempt to upload this picture I keep getting the error this file is to big. its only one picture. I don't why i'm getting this error
poppy1440
Bone Stock
Reply #11 on:
January 20 2011, 09:07:38 PM »
the picture can be viewed at turbobuick.com title(lock up question)
daveismissing
Reply #12 on:
January 20 2011, 10:23:15 PM »
link
http://www.turbobuick.com/forums/transmission-talk/337958-lock-up-question.html
Transmissions
converter won't lu
