Author Topic: Need to repair attempted theft damage  (Read 18721 times)
« Reply #15 on: January 15 2011, 10:08:14 AM »
Another vendor has infiltrated the board!  LOL
Offline gbsean
« Reply #16 on: January 15 2011, 06:18:58 PM »
Quote from: "SuperSix @ Sat Jan 15, 2011 9:28 am"
Quote from: "gbsean @ Fri Jan 14, 2011 11:56 pm"
we sell plates to repair that,,,basically you cut out the damaged area and weld in a new plate
WHo is 'we', and do you have pic links?
will get pics at work....
Offline gbsean
« Reply #17 on: January 15 2011, 06:21:09 PM »
Quote from: "Top Speed @ Sat Jan 15, 2011 10:08 am"
« Reply #18 on: January 15 2011, 11:31:02 PM »
« Reply #19 on: January 16 2011, 01:36:46 PM »
He got it.
Offline gbsean
« Reply #20 on: January 17 2011, 08:12:48 PM »
Quote from: "Top Speed @ Sun Jan 16, 2011 1:36 pm"
He got it.
anything you need is marked up 100% :rofl;
« Reply #21 on: January 17 2011, 08:39:28 PM »
I would expect nothing less!
« Reply #22 on: January 18 2011, 07:51:08 AM »
Quote from: "gbsean @ Sat Jan 15, 2011 6:21 pm"
Re: Need to repair attempted theft damage
« Reply #23 on: January 18 2011, 09:59:47 AM »
Don't waste your money on a 110 volt unit.
AJ___
« Reply #24 on: January 18 2011, 10:42:52 AM »
Quote from: "$1987 GN$ @ Tue Jan 18, 2011 9:59 am"
AJ___
Just for basic body work/exhaust?
I have no excuse for not getting a 220v - my electrical panel is in the garage.
OK - I need a basic starter unit, do the gas less ones work for my needs?
« Reply #25 on: January 18 2011, 12:21:09 PM »
Quote from: "SuperSix @ Tue Jan 18, 2011 10:42 am"
AJ___
The price difference between the 110 and 220 are trivial. Anyone I know that bought the 110 unit always trip the breaker if they use the high current setting. The cost difference from the non gas to gas is miniscule, get one that can use gas. You do not need to use the gas if not needed. You change the wire and change the polarity of the electrode and use the cored wire. Some units have a switch to change the polarity others you have to take a nuts off and and then move the cables and replace the nuts.
The gassless ones are great outside when there is wind.
If you are welding inside and doing panel work use the gas unit.
Panel stitching takes time, but well worth the effort.
Take a evening course at the local College cheap and good training.
With practice you will become proficient.
AJ___
« Reply #26 on: January 18 2011, 12:33:17 PM »
Awesome input. Thanks!
« Reply #27 on: January 18 2011, 01:50:08 PM »
Quote from: "$1987 GN$ @ Tue 18 Jan, 2011 11:21"
AJ___
I would agree that the gas unit works better but as far as a 110 unit not having enough power I'd have to argue with you there AJ. We use one in the shop all the time and have used it to weld quite a few race cars together. Never had a failure on a weld yet and haven't popped a breaker yet. You just have to check the load of the unit and the duty cycle so you can get the best one out there. As far as learning how to weld body panels, take your time and it will come out fine. This side took me about 12 hours to get it done right and if you look at it from about 10 feet, you can't tell it's been replaced.
« Reply #28 on: January 18 2011, 02:07:07 PM »
Quote from: "Charlief1 @ Tue Jan 18, 2011 1:50 pm"
Hi Charlie what 110 volt unit do you have and what the circuit setup is. That would help him to know what to buy. I was just stating what I have seen, I did not look into their wiring, breaker parameters.
Agreed it can be done; with the price difference today is it worth buying a 110 unit?
AJ___
« Reply #29 on: January 18 2011, 02:17:12 PM »
Quote from: "$1987 GN$ @ Tue 18 Jan, 2011 13:07"
AJ___
I didn't set it up AJ. I'd honestly have to look at it because I don't remember what unit it is but I do know it's several years old now. Century is a good one as well as Hobart. The 110 units are very useful and to be honest I'd like to have a 220 unit but this is what we've got right now so it's what we use. I'd also suggest that you get one for gas because you can use flux core in it if you have to do some welding outside. Just disconnect the gas and you're ready to go.
