87 GN T Tops lots of optionsMild build
87 GN T Tops lots of optionsMild build30 over with forged pistons, Arp main studs, with billet main caps, ported heads and intake, arp head studs, speed pro flat tapped 204/214 cam, 62 mm throttle body, mease plenum, Cotton Front mount, PT70 Ptrim, 72 lb injectors, dual nozzle Razor alky, TT Chip TH400 Trans with all the Goodies and a Trans brake.ATI convertor spec'd by anderson.Still working out some chassis issuesonly 11.5 so far
Quote from: "BadAssGN @ Mon Jan 10, 2011 12:27 pm"87 GN T Tops lots of optionsMild build30 over with forged pistons, Arp main studs, with billet main caps, ported heads and intake, arp head studs, speed pro flat tapped 204/214 cam, 62 mm throttle body, mease plenum, Cotton Front mount, PT70 Ptrim, 72 lb injectors, dual nozzle Razor alky, TT Chip TH400 Trans with all the Goodies and a Trans brake.ATI convertor spec'd by anderson.Still working out some chassis issuesonly 11.5 so farJesus, what do you live at, like 12,000 feet elevation? You've got way more in that setup.
Quote from: "DCEPTCN @ Mon Jan 10, 2011 2:35 pm"Quote from: "BadAssGN @ Mon Jan 10, 2011 12:27 pm"87 GN T Tops lots of optionsMild build30 over with forged pistons, Arp main studs, with billet main caps, ported heads and intake, arp head studs, speed pro flat tapped 204/214 cam, 62 mm throttle body, mease plenum, Cotton Front mount, PT70 Ptrim, 72 lb injectors, dual nozzle Razor alky, TT Chip TH400 Trans with all the Goodies and a Trans brake.ATI convertor spec'd by anderson.Still working out some chassis issuesonly 11.5 so farJesus, what do you live at, like 12,000 feet elevation? You've got way more in that setup.
Quote from: "BadAssGN @ Tue Jan 11, 2011 1:57 am"Quote from: "DCEPTCN @ Mon Jan 10, 2011 2:35 pm"Quote from: "BadAssGN @ Mon Jan 10, 2011 12:27 pm"87 GN T Tops lots of optionsMild build30 over with forged pistons, Arp main studs, with billet main caps, ported heads and intake, arp head studs, speed pro flat tapped 204/214 cam, 62 mm throttle body, mease plenum, Cotton Front mount, PT70 Ptrim, 72 lb injectors, dual nozzle Razor alky, TT Chip TH400 Trans with all the Goodies and a Trans brake.ATI convertor spec'd by anderson.Still working out some chassis issuesonly 11.5 so farJesus, what do you live at, like 12,000 feet elevation? You've got way more in that setup.
One pretty much stock other than the accufab reg and blocked off rocker hose and breather in the cover.Other one well too much junk.AJ___
